door lock actuator
Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By kliped
Thread: door lock actuator
  1. #1
    Active Member
    Join Date
    May 2016
    Posts
    99
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    I call BS (Received)
    0
    door lock actuator
    hey guys i was seeing if you could help me out real quick. i want to order a replacement driver door lock actuator because it seems mine is getting a bit weak and is not always opening the door like the other doors.
    My problem is i seem to be having a hard time determining exactly which part number i need. I have a 2011 sedan, automatic, remote start and passive entry (isnt this standard for all cts v sedans?), most of the gm oem parts websites have both part number 22922944 and 22922943 listed when i type in my exact information. then i emailed gmpartsdirect.com and they told me i need part number 23190383 lol they said they pulled that part number directly from gm catalog based on my info, wtf that part number is not even listed on their site under my vehicle lol, i am about to pull my hair out over this silly thing! the vin is 1G6DV5EP1B0164241 if that help at all. thanks guys!
  2. #2
    Active Member
    Join Date
    Feb 2012
    Location
    Minneapolis
    Posts
    1,646
    Likes (Given)
    0
    Likes (Received)
    17
    I call BS (Given)
    0
    1
    Just call the parts department at a Cadillac dealership. They'll be happy to give you the parts number. I need to get the actuator for my passenger rear door. It finally quit totally.
    Austin Performance Inc
    Home of the all original Sideswipe Air Deflector and Pocket Protector Heat Shield.
    I also sell new GM motors and parts for great prices. Cheapest available.
    New LSA shortblock $4495
    New Forged LSA short block $5450.
    2009 CTS-V, M6
    Metco 2.4 pulley
    E85
    FIC 1000s
    Single Wide HX
    Sideswipe air deflector
    BTR stage 2 cam
    LS7 throttle body
    Airaid
    ZL1 lid
    OBX headers
  3. #3
    Active Member
    Join Date
    Jan 2013
    Location
    Burbank, Ca
    Posts
    745
    Likes (Given)
    0
    Likes (Received)
    9
    I call BS (Given)
    0
    0
    Quote Originally Posted by SS1LE02 View Post
    Me too! Part numbers??? Lol
    Airaid w/ Green Filter, Ported LS7 TB, Ruskiyab ZL1 lid (milled, ported, reinforced and detailed), Vadder Destroyer HX, LPE Varimax, ID850's, Headers, WCCH ported heads, LT1Z's "2.5" cam, Johnson 2110's, C5R chain, Straub Trunions, Karch Blown w/ 2.45 upper, ATI w/8.6 lower, and all rebuilt block with Callies rods and Wiseco pistons. 5K fogs, Powder coated wheels with pretty little black Gorilla lugs, MT ET SS 305/35/19's, PAC Nav Unlock, 2 Recaro Sport Child seats, and blacked out everything. '11+ fender vents, back-up camera, Blacked-out Headlights (soon).
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Active Member
    Join Date
    Nov 2013
    Location
    San Antonio, TX
    Posts
    1,321
    Likes (Given)
    3
    Likes (Received)
    27
    I call BS (Given)
    2
    3
    I just installed a right rear yesterday, the last numbers were 38 i believe.
    184.7mph in the Texas Mile, Spring 2014. Just an average 75 mile daily driver.
  6. #5
    Active Member
    Join Date
    May 2016
    Posts
    99
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    I went ahead and ordered part# 23190383. Should be here in a couple days, will let you guys know if it works or not
  7. #6
    Active Member
    Join Date
    May 2016
    Posts
    99
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    hey guys, the part came in today and i went ahead and swapped them out. looks like part# 23190383 is the correct part number. the new actuator works great and no more "half open" or "no open" situations. i found this one on ebay for REALLY cheap here is the link 23190383 Door Lock Acutator Front Left Hand New OEM GM 2008-14 CTS Sedan/Wagon | eBay i was a bit skeptical, but it looks identical to the one i pulled out and the seller claims that they are left over oem assembly line parts that he buys directly from gm in bulk, hence why they are so cheap.
    the cable is the correct length, the only difference was where the metal rod, for the mechanical lock, attaches to the actuator there is a different type of clamp. in order to avoid not putting the rod back into its correct position, i went ahead a swapped over the old clamp
  8. #7
    Active Member
    Join Date
    Jan 2013
    Location
    Burbank, Ca
    Posts
    745
    Likes (Given)
    0
    Likes (Received)
    9
    I call BS (Given)
    0
    0
    Any rear door part numbers yet?
  9. #8
    Active Member
    Join Date
    May 2016
    Posts
    99
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    Quote Originally Posted by Sommer86 View Post
    Sorry, i only needed to do my driver side front.
  10. #9
    Active Member
    Join Date
    Feb 2014
    Location
    Detroit
    Posts
    812
    Likes (Given)
    2
    Likes (Received)
    40
    I call BS (Given)
    0
    0
    Was it easy to install? I have to replace my driver door and have the replacement actuator.
    2010 V 6MT - Thunder Gray, Recaros, Headers, Corsa Exhaust, Hennessey CAI, Velgen 20" wheels, Pilot SS tires
    2006 V -Sold
  11. #10
    Active Member
    Join Date
    Nov 2015
    Location
    Warren, MI
    Posts
    825
    Likes (Given)
    32
    Likes (Received)
    11
    I call BS (Given)
    0
    2
    Man, my local dealer back home bitches up a storm about how they can't release P#'s over the phone, it's looked up via the VIN so you don't need it, blah blah blah. Another reason that stealership can kiss my ass.
    Glad you got the right part on the first go round OP!
    2012 BDT Sedan - Recaro's, Ultraview, A6 >Build thread link<
    Stg 1 (as-purchased): Airaid, EE catchcan, 2.4" Metco, TR7IX, ported snout, Mamo LS7 TB, ID850's, ARH 1 7/8", Vadder Destroyer HX & CWA50 pump, ZL1 lid- 560rwhp/530rwtq SAE
    Stg 1.5: DMS (Flex)Fuel Trio, reinforced brick and Black Moon Aero- TBD
  12. #11
    Active Member
    Join Date
    May 2016
    Posts
    99
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    Quote Originally Posted by JD03Cobra View Post
    very easy install, just take your time and you wont damage/ screw anything up. also a word of advice, when removing the moister barrier, use a hair drier to heat up the sticky stuff and it will remove cleanly, then when you reinstall, use the hair drier again and it will reseal perfectly
    JD03Cobra likes this.
  13. #12
    Active Member
    Join Date
    May 2016
    Posts
    99
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    Hey guys I just wanted to give you a quick update. After replacing my driver side door actuator, everything seemed great. Shortly there after though the problem resurfaced, door half open, sometimes the door not opening at all. So a couple weeks ago, i went ahead and replaced the micro switches.
    i must say, i believe this might have been my problem all along, the door is much more responsive now and i havent had any issues in weeks. I cant say for sure if this was solely my problem, it may have been a combination of the two, because the old actuator did sound a bit sluggish, but i am just glad this problem is now resolved
  14. #13
    Active Member
    Join Date
    Feb 2017
    Location
    Sumter, South Carolina
    Posts
    52
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Quote Originally Posted by kliped View Post
    Did you replace the micro switch yourself? How much did the micro switch cost?
  15. #14
    Active Member
    Join Date
    May 2016
    Posts
    99
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    Quote Originally Posted by Texas_V View Post
    yep, i replaced it myself, its a pretty easy and straight forward job, i bought it on ebay for 49 dollars shipped
    Cadillac GM OEM 09-14 CTS Front Door-Handle Base Left 25979140 | eBay
  16. #15
    Active Member
    Join Date
    Feb 2014
    Location
    Detroit
    Posts
    812
    Likes (Given)
    2
    Likes (Received)
    40
    I call BS (Given)
    0
    0
    My issue was the actuator on the driver door. Only took me 30 minutes, very easy install and solved my problem!
    General Motors 22922943, Door Lock Actuator Motor
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    2006 V -Sold
  17. #16
    Registered User
    Join Date
    Nov 2015
    Location
    Cushing, OK
    Posts
    25
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    i just replaced my micro switches and the door is back to intermittently working. guess I will order the latch now.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
