Injectors or Fuel pump?
Results 1 to 10 of 10
  1. #1
    Active Member
    Join Date
    Feb 2014
    Location
    Somewhere out there
    Posts
    362
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    I call BS (Received)
    1
    I've been fighting P0171 and P0174 for a few days now, my tuner has also been noticing that I've been going lean and fuel pressure dropping to about 55 in the upper RPM'S. My LTFT are fairly high once the car is warmed up, about 14-17% while coasting, and if I give it gas they rise to about 21-24% between both banks with RPM. STFT however are fairly decent, always between 0-6%. I cant seem to pin point the issue, no real vacuum leaks either, O2 sensors are working also. I've been wondering if my cruising fuel pressure is OK, it sits at 35-36% at all times when cruising/normal driving. Any ideas and thoughts would be appreciated.
  2. #2
    Join Date
    Nov 2013
    Location
    Phoenix
    Posts
    1,851
    Likes (Given)
    36
    Likes (Received)
    22
    I call BS (Given)
    0
    0
    There is a test port on the OEM fuel rails where you can hook up a fuel pressure tester to see if your pressure is where it should be or dropping off. They rent them free at the auto parts stores if you don't own one. Its unlikely to be an injector issue when its both sides at the same time.
    Hidden Content
    Brands you can find at the Black Market!
    Procharger | Whipple | Borg Warner Turbos | Injector Dynamics | JMS| ARH | Cobb | Fore | Squash | Meisterschaft | Weld Wheels | Forgestar | MRR Wheels | M&H Tires | MHT Wheels | Weds Wheels | ProEFI | Megasquirt
    and many more! Call 480-382-1696 or email Hidden Content
    Hidden Content
  3. #3
    Active Member
    Join Date
    Feb 2014
    Location
    Somewhere out there
    Posts
    362
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    1
    Quote Originally Posted by BlackMarketRacing View Post
    My bigger question is, where is the pressure suppose to be? What's normal pressure on these cars?
  4. #4
    Join Date
    Aug 2011
    Location
    Austin, TX
    Posts
    3,585
    Likes (Given)
    43
    Likes (Received)
    164
    I call BS (Given)
    0
    2
    V2s have a fuel pressure sensor already. You can log it.
    Dedicated Motorsports - Austin, TX
    Hidden Content
    DSX Tuning - Personal projects
    Hidden Content
    Injector Dynamics dealer/supporter/lemming - The Flex Fuel Guy
    Hidden Content
  5. #5
    Active Member
    Join Date
    Feb 2014
    Location
    Somewhere out there
    Posts
    362
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    1
    Quote Originally Posted by DSteck View Post
    That's what I've been doing, I can definitely see the drop at higher rpms, I'm just trying to nail it down it my issue definitely being the pump. So if my fuel pressure is off at cruising then I know that's my issue. I still can't correlate that to the lean condition though, why would it be running lean while driving?
  6. #6
    Join Date
    Nov 2013
    Location
    Phoenix
    Posts
    1,851
    Likes (Given)
    36
    Likes (Received)
    22
    I call BS (Given)
    0
    0
    It should be at least 55psi with key on, engine off, and not drop more than 5psi or so within a minute.
    Hidden Content
    Hidden Content
  7. #7
    Active Member
    Join Date
    Feb 2014
    Location
    Somewhere out there
    Posts
    362
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    1
    I'll do that in just a few, what about pressure while driving?
  8. #8
    Active Member
    Join Date
    Feb 2014
    Location
    Somewhere out there
    Posts
    362
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    1
    Attached is a screenshot and log if you don't mind checking it out. Pressure started at 62 and dropped about 8 psi within a minute, could I say my pump is the issue based off of that?
    Attached Files Attached Files
  9. #9
    Join Date
    Aug 2011
    Location
    Austin, TX
    Posts
    3,585
    Likes (Given)
    43
    Likes (Received)
    164
    I call BS (Given)
    0
    2
    Double check for vacuum leaks. That's the most common cause for your scenario.
    Or the tune is just way off.
    Hidden Content
    Hidden Content
    Hidden Content
  10. #10
    Active Member
    Join Date
    Feb 2014
    Location
    Somewhere out there
    Posts
    362
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    1
    Well I think I got that issue sorted out. I am now leaning towards the big issue being my pumps. My file has Desired Pressure Low Flow set at 36 and normal set at 60. I take it low flow is less than optimal for cruising and I should be at 60ish while cruising ? Or am I looking at that wrong?
    Attached Thumbnails Attached Thumbnails Injectors or Fuel pump?-fue-pressure.jpg
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
