Service traction control, stumbling barely stay running limped home.
Results 1 to 18 of 18
  1. #1
    Registered User
    Join Date
    Apr 2016
    Location
    Greenville, SC
    Posts
    24
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    I call BS (Received)
    0
    So I have a 09 Stock M6 Sedan. I had just left the house heading down the road 25-35 mph and it started flashing the traction control, check engine light, and service stabiltrack. Started stumbling in all gears, barely made it home. Now it sounds like there is a rattle from the supercharger. Please help. I started researching and have seen possible Throttle body, supercharger rebuild/isolator. The supercharger was supposedly replaced under warranty before I got it.
  2. #2
    2X 9 second club
    Join Date
    Jul 2011
    Location
    In the Basket of Deplorable
    Posts
    9,357
    Likes (Given)
    41
    Likes (Received)
    238
    I call BS (Given)
    14
    12
    did you hit the rev limiter at any point?
    my 1st v2 did that once, and in the end it was a cracked sleeve.....not saying that one caused the other, but I was driving it hard, and it hit the limiter, went into limp mode and never ran quite right and later the piston broke at the ring land on #8 and cracked #6
    to get it out of limp mode, I reflashed the car and it started and ran, but never was the same up to the point where the piston broke.
    Silver surfer, 2016 Radiant Silver V3, 11.31@125 stock
    little red- 9.99@138 on the corn best mph 139 1/4 108.6 1/8 (sold)
    big silver - 9.63@142 on the spray (sold)
    my GM High Tech article:
    Hidden Content
    See the videos at:
    Hidden Content
  3. #3
    Registered User
    Join Date
    Apr 2016
    Location
    Greenville, SC
    Posts
    24
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    I might have about a week ago. I was driving it pretty aggressively, and had to slow quickly so I was braking, down shifting and shift into 2nd earlier than I should have. I was immediately hoping I didn't hurt anything, but it was fine for the last week or so.
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Active Member
    Join Date
    Jul 2016
    Location
    Pensacola, FL
    Posts
    110
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    Sounds like you burnt threw a spark plug wire to me.
    Just your typical 2.5/9.1 with a LJMS cam, bolt on car - JUSTIN WHITE TUNED.
  6. #5
    Registered User
    Join Date
    Apr 2016
    Location
    Greenville, SC
    Posts
    24
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Disconnected the battery, let it sit for a bit then tried again. Sounded a little better at idle, but after a minute the service traction control popped back up. Also the exhaust tone sounds a little deeper then normal.
  7. #6
    Registered User
    Join Date
    Apr 2016
    Location
    Greenville, SC
    Posts
    24
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Ok, so negative update...tried drive to the auto parts store less than a mile down the road. car sounds like its trying to eat it self. Codes thrown C05561, P0300, P1101, P0430. Bought some MAF sensor cleaner, headed home and started smoking then died. Pulled the intake tube covered in oil. Sprayed it out, sprayed MAF, and throttle body. Got it started for a minute then it died again and now nothing when turn the key.
  8. #7
    Registered User
    Join Date
    Jan 2017
    Posts
    2
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    I had this happen on ctsv 2009 with 49K km. Its due to misfire. Craked piston
  9. #8
    Active Member
    Join Date
    Nov 2014
    Posts
    176
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    ABS sensor failure or ABS module failure. I have had it on my Yukon; and Jetta; it can throw the car into limp mode.
  10. #9
    2X 9 second club
    Join Date
    Jul 2011
    Location
    Posts
    9,357
    Likes (Given)
    41
    Likes (Received)
    238
    I call BS (Given)
    14
    12
    I would run a scope into the 7 and 8 bores.
    Hidden Content
    See the videos at:
    Hidden Content
  11. #10
    Active Member
    Join Date
    Jan 2015
    Location
    Toronto, ON
    Posts
    2,536
    Likes (Given)
    145
    Likes (Received)
    72
    I call BS (Given)
    7
    2
    Sucking oil into the intake means oil is getting past the piston. Sorry to say, but Evil V gave you the most possible cause back in post #2. Keep everyone updated with what you find out from the scope. Post pics of the plugs as you pull them, I bet you'll find one with a bent ground electrode.
    2009 CTS V Black Raven Sedan, M6, Recaro's, Ultraview
    Stage 0.6 Airaid CAI, Kooks 1 7/8" LT's, Kooks catted xpipe, stock mufflers, Mamofied LS7, NGK TR6, SM Dual CC, 160F stat, Dynojet tuned by Dave @dasilvamotorsport, SAE 526hp/508tq/91oct
  12. #11
    Registered User
    Join Date
    Apr 2016
    Location
    Greenville, SC
    Posts
    24
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    #2 and 4 compression down to 60lbs. gonna be pulling apart soon. Supercharger will be going to Brett and other mods will depend on damage. Hoping the damage is minimal.
    I will update as I figure out what is up.
  13. #12
    Registered User
    Join Date
    Apr 2016
    Location
    Greenville, SC
    Posts
    24
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    UPDATE...motor is apart. From what I am told, the piston rings on the right side were all seized. Bore looks good, piston/combustion chambers look good, no apparent damage to heads/valvetrain. Is there something I need to be looking for to cause the 1 side to sieze? Overheating, injector issues, etc?
  14. #13
    2X 9 second club
    Join Date
    Jul 2011
    Location
    Posts
    9,357
    Likes (Given)
    41
    Likes (Received)
    238
    I call BS (Given)
    14
    12
    have they mic'ed the bores to make sure they are all round? mine, one was not in round and had a hairline crack.
    Hidden Content
    See the videos at:
    Hidden Content
  15. #14
    Registered User
    Join Date
    Apr 2016
    Location
    Greenville, SC
    Posts
    24
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    all have to ask.
  16. #15
    Registered User
    Join Date
    Apr 2016
    Location
    Greenville, SC
    Posts
    24
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    So it seems a clogged cat on the passenger side was a contributing factor. Right side rings seized causing loss of compression. No damage to bores or heads. Being rebuilt with forged rods and pistons, cam kit from Hawks motorsports, Jokerz rebuilt and ported SC/Snout to Ported Gold blade LS7 TB. ID850, TSP headers to x pipe stock mufflers, Airaid CAI. Looking forward to getting it back and seeing what the new numbers will be. Planning and adding a ZL1 lid, reinforced brick, and killer chiller also.
  17. #16
    2X 9 second club
    Join Date
    Jul 2011
    Location
    Posts
    9,357
    Likes (Given)
    41
    Likes (Received)
    238
    I call BS (Given)
    14
    12
    A melted cat is bad news. these cars just cant take it with the stock cats over ~600-650 at the wheels, and probably are on borrowed time with any mods.
    Hidden Content
    See the videos at:
    Hidden Content
  18. #17
    Registered User
    Join Date
    Apr 2016
    Location
    Greenville, SC
    Posts
    24
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    It was stock, but I total understand. Very expensive lesson on the cats, lol!
  19. #18
    Registered User
    Join Date
    Feb 2017
    Posts
    12
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Damn.I hate learning those lessons. I have a v6 Syclone 4.3L that only made it 500.....
    God luck with the New build.
    Dan
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
