Key Not Detected
Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By Nightstalker
  • 1 Post By TurboCoupe
Thread: Key Not Detected
  1. #1
    Active Member
    Join Date
    Feb 2015
    Location
    Big Money Texas (BMT)
    Posts
    113
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    I call BS (Received)
    2
    Key Not Detected
    I've read a few threads on this but, can't seem to remedy my issue.
    I went to open my car this morning and the door wouldn't open. So, I figured the battery in the fob was dead. I grabbed the other fob and it wouldn't open the car either.
    I then replaced the batteries in both remotes and that hasn't fixed the problem. I learned about the slot in the center console while searching ... that works.
    Any suggestions?
    "There is no elevator to success. You have to take the stairs."
  2. #2
    Active Member
    Join Date
    Feb 2015
    Location
    Posts
    113
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    2
    Disconnecting the battery for a few minutes didn't seem to help.
  3. #3
    Jaguar
    Join Date
    Oct 2014
    Location
    Houston, TX
    Posts
    545
    Likes (Given)
    24
    Likes (Received)
    19
    I call BS (Given)
    4
    5
    Probably not the fix you need but I've noticed if the fob is in the same pocket as my phone, I get that message on the DIC sometimes.
    2012 OBM Coupe A6
    Stage 1 - Airaid CAI, FIC1000's, Dsteck Flex Sensor, HX Tank, Varimax Pump, QTP Cutouts, G-Force Tuned E85 - 581rwhp/536rwtq
    Stage Airaid - G-Force Tuned - 515rwhp/487rwtq (176.2mph TX Mile) Hidden Content
  4. #4
    Active Member
    Join Date
    Feb 2015
    Location
    Posts
    113
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    2
    Quote Originally Posted by BlueCoupeV View Post
    It won't unlock the car with the key in my hand. None of the buttons work on either key fob. It just seems weird that it happened all of the sudden.
  5. #5
    Active Member
    Join Date
    Nov 2016
    Location
    St Louis Metro Area
    Posts
    84
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    My fob went bad. Guy at the dealership said it was not uncommon.
  6. #6
    Registered User
    Join Date
    Oct 2016
    Posts
    11
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Mine was doing the same thing. All I did was change the batteries and been fine ever since
  7. #7
    Active Member
    Join Date
    Oct 2011
    Location
    Deserts of NM
    Posts
    1,939
    Likes (Given)
    40
    Likes (Received)
    49
    I call BS (Given)
    1
    0
    Not being insulting, but is are the new batteries in correctly?
    Matticus likes this.
    Hidden Content
    2010 Black Fully Optioned Fully Built
    ID850's - Manley Rods - Manley Pistons - Ported/Polished Heads - Kooks Longtube headers - Corsa exhaust
    ARP Studs - Custom Ground Cam - IW 8.6 lower 2.4 upper - Track Attack HX - NorCal Tank - ZL1 Lid
    High Flow HX Pump - Moroso Catch Can - Passport CI 9500 keeping tickets in check when in Mexico
    2009 Radiant Silver Fully Optioned (SOLD) because I'm a dumb ass
    "Smart people learn from others mistakes, Fool's learn from their own"
    Sorry if my posts arent as expert as you would like and have made you more stupid than you already were...
  8. #8
    Active Member
    Join Date
    Feb 2015
    Location
    Posts
    113
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    2
    Quote Originally Posted by Nightstalker View Post
    YES, I just pulled it apart to make sure.
  9. #9
    Active Member
    Join Date
    Feb 2015
    Location
    Posts
    113
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    2
    I just tried the spare key and it works now. I replaced the battery in it earlier but, it wouldn't open the door. I reset the car battery and didn't think to try it. So I guess I have a bad key fob ... one working key is better than no working key.
    Thanks for the suggestions guys.
  10. #10
    Active Member
    Join Date
    Oct 2014
    Location
    Beaumont, TX
    Posts
    339
    Likes (Given)
    8
    Likes (Received)
    9
    I call BS (Given)
    0
    0
    Mine has been acting dumb too....the only button that will work is the trunk pop and then all of a sudden the other keys work. Also that the lock lamp lit up on the dash...dunno what that means.
    2012 CTSV Coupe A6
    SW full exhaust, 2.5/9.5, LT1Z 2.5, Greg Good Ported Heads, Ported Blower/Snout, ID1000s, Track Attack, ZL1 lid, Airaid CAI, Ported LS7 TB
    Hidden Content
  11. #11
    Active Member
    Join Date
    Jan 2016
    Posts
    1,013
    Likes (Given)
    0
    Likes (Received)
    13
    I call BS (Given)
    0
    0
    Quote Originally Posted by TurboCoupe View Post
    Means your car is going to blow up. Better D-Mod and send me your parts before it's too late
  12. #12
    Active Member
    Join Date
    Oct 2014
    Location
    Beaumont, TX
    Posts
    339
    Likes (Given)
    8
    Likes (Received)
    9
    I call BS (Given)
    0
    0
    Quote Originally Posted by Mikeyboyeee View Post
    The engine was put together using gorilla glue....it will never come apart again. Sawwy. Let her blow!
    Mikeyboyeee likes this.
    2012 CTSV Coupe A6
    Hidden Content
  13. #13
    Active Member
    Join Date
    Oct 2011
    Location
    Deserts of NM
    Posts
    1,939
    Likes (Given)
    40
    Likes (Received)
    49
    I call BS (Given)
    1
    0
    I have found that my buttons get pushed while in my pocket with other things. Sometimes my trunk pops, sometimes I think they are constantly pressed because my batteries wear out very quickly. I dont even wear skinny jeans
    Hidden Content
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
