Bad Alternator? Bad Actuator? (video w/ sound)
Results 1 to 4 of 4
  1. #1
    Active Member
    Join Date
    Mar 2014
    Location
    Michigan
    Posts
    74
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    I call BS (Received)
    0
    Picked up my car from the body shop (they did some touch up work) and my V was making a humming noise. Battery voltage on the dash read 15.5V. Then when I shut the engine down, I hear this noise. I think the sound is coming from the right side of the engine. It sounds like some actuator is trying to move but getting stuck...or kind of like the sound an airplane make when they are locking the landing gear in place. Since the battery voltage is reading high, I was thinking it could be the alternator, but then that sounds after shutdown doesn't make much sense to me.
    Please help!
    http://vid282.photobucket.com/albums...3/File_000.mp4
    2010 CTS-V Sedan, M6, Thunder Gray, Recaro, no Sunroof, de-chromed, lower, ported TB, CAI, Magnaflow
    Why don't you go back to your home on Whore Island?
    Hidden Content
  2. #2
    Active Member
    Join Date
    Mar 2014
    Location
    Michigan
    Posts
    74
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Still trying to figure this out... I moved the car yesterday and it seemed to be fine, but I'm still trying to figure out what happened here.
    Hidden Content
  3. #3
    Join Date
    Jul 2011
    Location
    Los Angeles
    Posts
    14,684
    Likes (Given)
    341
    Likes (Received)
    307
    I call BS (Given)
    10
    19
    Any chance it's your intercooler pump?
    I say this only because it can have a delay after shutdown, but it does sound a bit loud for that.
    Sales@dynamicflowconcepts.net
    Dynamicflowconcepts.net
  4. #4
    "V"roooooom
    Join Date
    May 2015
    Location
    Pooler, GA
    Posts
    21
    Likes (Given)
    2
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    ***If the alternator is working well, your multi-meter should read somewhere in the vicinity of 14 volts (typically 13.8-14.2). If it is reading excessively higher than 14 volts (greater than 15 volts) it is possible that the voltage regulator on your alternator is faulty or going bad. If it is reading lower than 13-14 volts, there are a number of possibilities as to the reason. First, it is possible that your engine idle speed is too low for the alternator to put out sufficient voltage/power. Try revving up the engine to 2000 RPM or higher and take a reading. If the voltage is still too low, check to be sure all the connectors on your alternator are tight and that the alternator belt is not slipping and is spinning on the pulley correctly. If it is still not putting out sufficient power, then the alternator’s voltage regulator could be bad or the alternator itself may need replaced. - From the Internet ***
    As for me, I had to change out my alternator because it was not working properly. My voltage was in the 11 range. It made a noise through the power steering that would sound like engine feedback through the speakers. (the alternator is located at the front lower driver side)
    Hidden Content
    2011 CTS V, RECAROS, ULTRAVIEW, EIBACH SPRINGS, CROSS DRILLED AND SLOTTED ROTORS, CF AIRAID
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
