Car won't crank, fuel pump primes
Results 1 to 5 of 5
  1. #1
    Registered User
    Join Date
    Nov 2015
    Location
    Cushing, OK
    Posts
    13
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    I call BS (Received)
    0
    My 09 A6 sedan has decided to not start. Issue started with a bad battery. I have replaced the battery and it still would not start. It was suggested to use the key to unlock the door and then the car started. So I replaced the key fob battery and had no trouble for a day. Now once again the car will not start.
    The lights, locks, truck all work. The fuel pump primes but the car doesn't attempt to crank. Anyone know where I should begin to troubleshoot?
  2. #2
    Active Member
    Join Date
    May 2016
    Location
    Michigan
    Posts
    236
    Likes (Given)
    0
    Likes (Received)
    6
    I call BS (Given)
    0
    0
    Will it let you turn the key all the way?
    Sounds like key fob is not detected. Maybe reprogram? Or the reciever/brain that handles the signals is messed up.
    Check fuses?
    2013 TGC V Sedan M6
    Crane Cam, BTR DVS, BTR moly PRs, ATI damper, 8.66", 2.55", LPE Iso, Kooks long tubes, Kooks cat X-pipe, Corsa Perf. Axle-back, FIC 72/lb, MSD BAP, MSD plugs, NGK plugs, 160* T-stat, Centerforce DYAD twin-disc, Airaid intake, Mich Pilot SS tires. Cooling and E85 coming soon!
  3. #3
    Registered User
    Join Date
    Nov 2015
    Location
    Cushing, OK
    Posts
    13
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    I saw a post about the pedal position sensor, so I moved the throttle up and down and the car started. This morning it started without issue.
  4. #4
    Registered User
    Join Date
    Nov 2015
    Location
    Cushing, OK
    Posts
    13
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Doesn't start again. Going to get a scan tool to see what is showing
  5. #5
    Registered User
    Join Date
    Nov 2015
    Location
    Cushing, OK
    Posts
    13
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Purchases a scan tool. Even though the engine light stays on when it doesn't start, there are no codes found.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
