solution for V2 rear diff noise
Results 1 to 9 of 9
  1. #1
    Registered User
    Join Date
    Aug 2016
    Location
    Long Beach, CA
    Posts
    6
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    I call BS (Received)
    0
    Whats up guys, I joined a couple months ago, this is my first post. As many people on here my v2 started to make a growling noise in the back, relative to speed and load, the gear whine, passenger side seal leaking, all symptoms my car had. From my experience I knew it had to be aither a pinion bearing, or carrier bearing. I started digging through forums to get some info about this noise. Personally i think tgat failure is due to poor oil quality, or incorrect filling level from gm. From what I picked up, either they would be replaced, gm eould pay a small percentage, parts are unavailable, etc... Nobody had a solution because according to techs at gm it was unserviceable. Last Saturday I decided to just bring the diff down and tear it apart. What i found was broken down carrier bearings and races. Bearings and races were pitted, that caused bearing play, that lead to increased backlash which caused the whining sound. Once i had the diff out of the case, taking the races out was a challenge, since the diff wasnt designed to be repaired. Nothing a good toolbox cant handle. Here are some pics.
    Attached Thumbnails Attached Thumbnails solution for V2 rear diff noise-2016-09-29-00-04-33-1036574407_1475167645432.jpg solution for V2 rear diff noise-2016-09-29-00-04-38-1492196540_1475167658117.jpg solution for V2 rear diff noise-2016-09-29-00-04-42-1873483947_1475167670726.jpg solution for V2 rear diff noise-2016-09-29-00-04-47-202774020_1475167685035.jpg solution for V2 rear diff noise-2016-09-29-00-04-52-1291270962_1475167704770.jpg
    solution for V2 rear diff noise-2016-09-29-00-04-56-179385482_1475167730116.jpg solution for V2 rear diff noise-2016-09-29-00-04-59-1352050745_1475167745361.jpg solution for V2 rear diff noise-2016-09-29-00-05-07-1060904316_1475167763017.jpg solution for V2 rear diff noise-2016-09-29-00-05-10-464551528_1475167782811.jpg
  2. #2
    Active Member
    Join Date
    Aug 2014
    Location
    In a Garage or a Bar..or a garage with a bar in it.
    Posts
    1,352
    Likes (Given)
    2
    Likes (Received)
    63
    I call BS (Given)
    0
    0
    Damn. You just went right at it man. Kudos to you!
  3. #3
    Active Member
    Join Date
    Jan 2016
    Location
    Virgnia
    Posts
    745
    Likes (Given)
    27
    Likes (Received)
    30
    I call BS (Given)
    0
    2
    Excellent first post !!!
  4. #4
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    12,883
    Likes (Given)
    0
    Likes (Received)
    376
    I call BS (Given)
    0
    12
    Gotta agree, this is stellar 1st post material, thank you and welcome.
    I know if my Diff shit a bearing, I have a local diff shop that I would give them a shot and rebuilding it.
    I doubt the Ring and pinion are replaceable, but bearings should be serviceable.
    Subscribed for your results.
    679RWHP 662RWTQ
    BMF cam
    Ported SC/Snout/90TB
    Kooks LT w/cats stock muffs
    ID850's
    IW 9.1/2.55
    Airaid w/green filter
    Katech+W4M HX ZR1 pump
    Norcal ice tank
  5. #5
    Join Date
    Jul 2011
    Location
    Los Angeles
    Posts
    14,690
    Likes (Given)
    341
    Likes (Received)
    308
    I call BS (Given)
    10
    19
    Excellent.
  6. #6
    Active Member
    Join Date
    Aug 2015
    Posts
    205
    Likes (Given)
    1
    Likes (Received)
    4
    I call BS (Given)
    0
    0
    Subscribed for results on this.
  7. #7
    Registered User
    Join Date
    Aug 2016
    Location
    Long Beach, CA
    Posts
    6
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Thanks guys, if anyone has any questions about this little project feel free to ask. I realized I posted this up in the wrong area I typed this up during breakfast, on top of that I've never posted anything in any forum.
  8. #8
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    12,883
    Likes (Given)
    0
    Likes (Received)
    376
    I call BS (Given)
    0
    12
    Moved to the troubleshooting area
    679RWHP 662RWTQ
    BMF cam
    ID850's
    IW 9.1/2.55
    Norcal ice tank
  9. #9
    Active Member
    Join Date
    Jul 2011
    Location
    Chicagoland :(
    Posts
    1,735
    Likes (Given)
    43
    Likes (Received)
    30
    I call BS (Given)
    1
    0
    Strong work tearing into it!
    2011 Sedan Raven Black - Forged 406LSA, Ported Heads and blower, Kooks Headers w/cats, Airaid Intake, 9.55 lower, GT11 Cam and BTR springs, Ported LS7 TB, ZL1 Lid, WeaponX Heat Exchanger + Stewart pump, NORCAL HX Tank, ID850's, Speed, Inc. dyno tune, D3 springs, super secret sway bars, WeaponX diff cooler
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
