This is something that everyone that has every had their boost bypass bracket moved needs to check. When checking my boost bypass valve bracket I noticed that it was bolted with the bracket shifted away from the motor.
At this time I had 4 threads showing on my adjustment screw before it lightly touched the plate. Shifting forward the whole bypass valve with its bracket it moved the entire actuator arm and than I realized that if its mounted with the bracket too far back it will pull the arm on its own. Meaning you can play around with the screw all you want but if the bracket is not correctly mounted the actuator arm will be slightly pulled.
From adjusting the bracket I went from 4 threads to touch the plate to 1 thread to touch the plate. I can see this being an issue with some people having boost problems so i'll let the photos do the talking.....
