What a terrible night. Use jack stands!
Page 1 of 3 123 LastLast
Results 1 to 30 of 73
Like Tree16Likes
Thread: What a terrible night. Use jack stands!
  1. #1
    Active Member
    Join Date
    Apr 2013
    Location
    Calgary AB
    Posts
    4,526
    Likes (Given)
    0
    Likes (Received)
    114
    I call BS (Given)
    0
    I call BS (Received)
    9
    So ill start out by saying I'm fine and wasn't hurt but the car is a bit banged up. I began the day wanting to put on my Eiback lowering springs and had read up about it for a while so felt comfortable doing it. I have a new garage so I am not fully set up but I had all my tools and to work I went.
    Rear left was fine, the biggest problem was pushing the push pin out of the top of the grommet more because there was a lot of road grime in there. Rear right same thing, lots of grime but had it done in 20-30 minutes.
    Front passenger side I jack the car up, slide the jack stand under it. I didn't have it high enough so I pull the jack stand out and go to reach for the jack. *Kaboom* Jack releases all pressure the the car drops onto the jack. Front wheel was already off, looking back this could have been avoided had I left it on but I broke the lugs loose when it was on the ground, then I jacked it up and for some reason took the wheel off then went to put the jack stand under the car. Clearly very stupid and I was really lucky to not have my hands/arm or the jack stand under the floor boards when the car dropped like that.
    The floor jack stopped the momentum and the rotor did hit the ground but it didn't damage the rotor. The side sill on the other hand is done. The door managed to make it unscathed and the gaps looked fine after I got the car jacked back up.
    I was using my father-in-law's "hand me down aluminum" jack. Ive jacked my Mercedes sprinters with it, my wife's venza, never had a problem but it just decided to fail when I had it under the V
    I am happy I wasn't under it, and im not even that upset because it could have been way worse. Let my mistakes be a lesson, use jack stands and be safe under your cars, I know I have a kid and family that depend on me and its not worth pulling short cuts.
    now for the ugly...
    Not having anything to get the car off the ground I had to swing up the road and I bought a nice new jack (that cost more then I would like to admit) raised the car, blocked it for the night and ill tackle the rest tomorrow.
    cav454 likes this.
    Current mods
    Lt1z stage 2 cam - johnson lifters - Dynospeed 4.5 intake/Green filter - Mamo LS7 ported TB - ARH headers and x-pipe to stock mufflers - Weapon X Track attack HX - weaponX carbon fiber spoiler and side blades - Varimax HX pump - NGK afx wide band - 2.45 Griptech upper - ATI lower 8.8 ring - Green belt - idler pulley - Id850s, Zl1 lid - NGK TR7ix - MSD wires - Mighty mouse catch can - BMR ice box - Side Swipe -
    160ish or 170 thermostat- Tuned.
  2. #2
    Active Member
    Join Date
    Mar 2013
    Posts
    622
    Likes (Given)
    0
    Likes (Received)
    24
    I call BS (Given)
    0
    0
    Wow... glad you're ok man.
    I think about my future and kids whenever I have to work under the car. I always use a minimum of 2 jacks if jacking up one side, and 3 if entire car... and at the same time, I use jackstands or ramps positioned as a safety precaution without any weight on them in case the jacks fail. I don't feel comfortable under the car with all the weight on just jackstands.
    t.j.t likes this.
    Build Stage 1.1: Hidden Content
    Build Stage 1: Hidden Content
    Exterior: Hidden Content
    Airaid + OEM: Hidden Content
    Single Saikou Michi + Quick Release Mount: Hidden Content
    3" Coupe Exhaust: Hidden Content [/QUOTE]
  3. #3
    Active Member
    Join Date
    May 2014
    Location
    Maryland
    Posts
    116
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    what kind of jack was it?
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Active Member
    Join Date
    Aug 2013
    Location
    NorCal
    Posts
    2,156
    Likes (Given)
    53
    Likes (Received)
    77
    I call BS (Given)
    14
    4
    Yikes!!! Glad you're ok.
    I had my 2 previous cheapo made in china jacks lose pressure like that, but I wasn't under the vehicle either.
    I decided then to spend the money on a good jack, even if I don't get under the car without jacks in place.
    It cost me $400. Buy once, cry once.
    t.j.t and pcf_mark like this.
    2011 CTS-V
  6. #5
    It's got an intake tube!
    Join Date
    Jan 2012
    Location
    State of Confusion
    Posts
    7,949
    Likes (Given)
    572
    Likes (Received)
    224
    I call BS (Given)
    28
    21
    Very fortunate, glad you weren't hurt. Jack stands FTW!
    t.j.t likes this.
    2011 White Diamond Sedan A6, 10.7 @ 130 (stage 1)
    750 RWHP (138ish through the trapper) So far... (stage 2)
    Click here -> Hidden Content
    Hidden Content
  7. #6
    Active Member
    Join Date
    Apr 2013
    Location
    Calgary AB
    Posts
    4,526
    Likes (Given)
    0
    Likes (Received)
    114
    I call BS (Given)
    0
    9
    Quote Originally Posted by VindictiV View Post
    Ill check in the morning, I need a break from the car for the night.
    My father in law felt really bad, hes a big time gm guy and loves the V and to help with the car. I told him not to feel bad, it could have happened with any jack, and in the end its just a car.... a nice car.
    Bad1nfluence likes this.
    Current mods
  8. #7
    Active Member
    Join Date
    Jul 2013
    Posts
    879
    Likes (Given)
    0
    Likes (Received)
    23
    I call BS (Given)
    0
    1
    Had a variation on this story with a previous car. I was jacking up one side on an epoxied floor. The 'down' side tires slipped and the car fell off the jack. Scary as hell.
    t.j.t likes this.
  9. #8
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    13,647
    Likes (Given)
    0
    Likes (Received)
    397
    I call BS (Given)
    0
    13
    Had my jack fail as I was pulling the jack stand out from underneath car and the jack stand impaled the rocker cover.
    Hydraulic cylinder lost a seal, bought new jack next day and inspect often
    $150 plus paint to replace rocker cover. Good as new.
    Glad you were not hurt bro, pretty easy fix though
    t.j.t likes this.
    679RWHP 662RWTQ
    BMF cam
    Ported SC/Snout/90TB
    Kooks LT w/cats stock muffs
    ID850's
    IW 9.1/2.55
    Airaid w/green filter
    Katech+W4M HX ZR1 pump
    Norcal ice tank
  10. #9
    Active Member
    Join Date
    Oct 2013
    Location
    Shelton, CT
    Posts
    723
    Likes (Given)
    0
    Likes (Received)
    28
    I call BS (Given)
    0
    3
    Could've been much worse man thankfully you're okay, if the plastic rocker molding is the only damage its a cheap and easy fix.
    t.j.t likes this.
  11. #10
    Active Member
    Join Date
    Oct 2012
    Posts
    7,123
    Likes (Given)
    2
    Likes (Received)
    152
    I call BS (Given)
    0
    11
    Looks like a harbor freight aluminum 60 dollar special. They're awful jacks
    2013 CTSV Wagon A6
    10.19@132mph 1.47 60 foot
    stg 2 lt1z cam, 10.5 lower, air raid intake, b&b test pipes, ls7 tb on 93 octane 627rwhp
    New setup:
    stg 2.5 lt1z cam 10.5 lower air raid TSP Longtubes jokerz port 660rwhp
    10.19@137 1.50 60 foot.
  12. #11
    Active Member
    Join Date
    Jun 2012
    Location
    Spring/Woodlands TX
    Posts
    14,535
    Likes (Given)
    62
    Likes (Received)
    588
    I call BS (Given)
    0
    11
    I had a similar situation just a couple of days ago, bit fortunately nothing fell. Most floor jacks are hinged right at the top of the lifting arm. There's usually a pin and a "control arm" that keeps the contact surface parallel to the floor. You can see it well on this picture below. Well on one of my jacks that flat metal bar is connected down at the base to a pin. It slides over the pin and is retained with a snap ring. I had my wife's car on the jack (with jack stands but not ON the stands, weight was still on the jack). I went to lower the car onto the stand and the jack wouldn't go down. I then noticed the retaining ring had rusted off or something and the metal bar had slipped off the lower pin. It's down by the piston so you can't really see it well unless it fails....
    This would allow the upper contact perch to pivot. It could have simply tipped and dumped the car off the jack. Thankfully there's an identical bar on both sides and the second one kept things level. And fortunately the car was lifted in such a way that it wasn't under any lateral forces at the lifting point that would make it til. But it was one of those powerful reminder moments...
    2014 OBM/Titanium CTS-V Wagon "The Blue Whale"
    Auto, All Options, Interior 100% stock.
    Custom touches here and there...needs driver mod badly!
    7xx to 8xx rwhp
    2015 Audi SQ5 Prestige Glacier White Metallic + Gloss Piano Black trim "Snow White"
    Black leather interior, 8 Spd ZF Auto, all options
    Pulley and tune
    21" RS6 wheels /Super Sport 285's all around / Lowered on KW's
  13. #12
    Active Member
    Join Date
    Jun 2014
    Location
    Somewhere West of Chicago
    Posts
    259
    Likes (Given)
    66
    Likes (Received)
    5
    I call BS (Given)
    1
    0
    Will definitely be using jack stands next time I have her up! Glad you are okay!
    t.j.t likes this.
    Black 2010 CTS-V Sedan
  14. #13
    Active Member
    Join Date
    Mar 2012
    Location
    Dallas, TX
    Posts
    6,591
    Likes (Given)
    12
    Likes (Received)
    132
    I call BS (Given)
    1
    10
    This thread just got my wife on board with me buying a Ranger Quickjack BL-5000. I've been wanting one for a while, id still stick a jack stand under the car but it would make getting all 4 wheels up faster and safer
    CURRENT: 2016 Corvette Stingray - M7 - Arctic White - 773rwhp / 592tq
    ^^Mods: LG Headers, CAI, A&A Supercharger, Cam, Meth. CPR Fuel System, etc...
    SOLD: 2015 Corvette Stingray - A8 - Arctic White - 671rwhp / 556tq
    SOLD: 2009 CTS-V Sedan - M6 - Black Raven - 740whp / 638tq
    SOLD: 2011 CTS-V Coupe - M6 - Thunder Grey - 621rwhp / 605tq
    SOLD: 2004 CTS-V Sedan - M6 - Black Raven - 474rwhp / 486tq
  15. #14
    Active Member
    Join Date
    Aug 2011
    Posts
    4,045
    Likes (Given)
    7
    Likes (Received)
    36
    I call BS (Given)
    0
    2
    Quote Originally Posted by 555ctsv View Post
    Now I want one! Damn that would be handy
    555ctsv likes this.
  16. #15
    Active Member
    Join Date
    Jul 2014
    Location
    Dallas
    Posts
    5,837
    Likes (Given)
    207
    Likes (Received)
    209
    I call BS (Given)
    9
    13
    Mod parties at your place. That thing looks sweet!
    555ctsv likes this.
    M6: 10.70 @ 136mph
    "I've ridden in a lot of what I thought were fast cars, but yours was the first one to ever give me butterflies."
    Hidden Content
  17. #16
    Active Member
    Join Date
    May 2013
    Location
    Kentfield, CA
    Posts
    777
    Likes (Given)
    9
    Likes (Received)
    19
    I call BS (Given)
    1
    1
    Glad you're ok man. This is always something that is in the back of my mind when I jack up the car. I always scramble to get a jack stand under the car as quickly as possible.
    Wow, and pretty reasonable at $1300. Tempting...
    t.j.t likes this.
  18. #17
    Join Date
    Jun 2014
    Location
    Knoxville, TN
    Posts
    5,474
    Likes (Given)
    1376
    Likes (Received)
    138
    I call BS (Given)
    10
    29
    Not as bad as mine. Sitting on side of interstate just blew motor. Fuck
    Hidden Content
    2 New Splitter Designs and New Rocker Blade design available NOW!
    Splitters $329- Rocker Blades $299
    Hidden Content <---
    2012 Coupe, A6, 2.5/9.1, FIC 1000’s, ZL1 lid, Varimax pump, DMS H/X, ARH headers, no cats, B&B mufflers, 4.5" G Force CAI, 102 NW with Jokerz ported snout, Trick Flow 255 ported by Tony at Xtreme CFM, Vengeance Racing E85 Flex Fuel Conversion, Vengeance PCM Tune, DMH Cut Outs, MRR 228 20” wheels, 255 Michelin Super Sports, 305 Michelin Pilot Sport Cup 2s, Black Moon Products ‘Rocker Blades” and BMP front splitter coming soon. 712 on 93, 767 on E85
    Hidden Content
  19. #18
    Active Member
    Join Date
    Oct 2012
    Posts
    587
    Likes (Given)
    0
    Likes (Received)
    6
    I call BS (Given)
    0
    0
    I had the seal blow out in the pretty blue Harbor Freight jack too. I was shimmying the car around with the wheel still on just trying to reposition it closer to the wall. Drop w/o warning like a stone. I needed to change my shorts after that.
    '12 V Wagon, M6, CRT, Recaros, chrome wheels, no sun roof
    '68 Ford Bronco (have to drive something in the snow)
    '68 Corvette 427 (basic 11 second street car)
    '60 Corvette 283/250hp restoration in progress
  20. #19
    Active Member
    Join Date
    Jun 2014
    Location
    Posts
    259
    Likes (Given)
    66
    Likes (Received)
    5
    I call BS (Given)
    1
    0
    Quote Originally Posted by Black Moon View Post
    Holy crap sorry to hear that - definitely start a new thread with details.
  21. #20
    Join Date
    Jun 2014
    Location
    Knoxville, TN
    Posts
    5,474
    Likes (Given)
    1376
    Likes (Received)
    138
    I call BS (Given)
    10
    29
    Quote Originally Posted by LucasVDW View Post
    I did. Terrible night TN style
    Hidden Content
    Hidden Content <---
    Hidden Content
  22. #21
    Active Member
    Join Date
    Jun 2012
    Location
    Spring/Woodlands TX
    Posts
    14,535
    Likes (Given)
    62
    Likes (Received)
    588
    I call BS (Given)
    0
    11
    Now THAT looks cool. I didn't see where it said how much each of the two lift units weigh. Looks like you could hang them on the wall pretty easily and they're only 4 inches thick when folded. Man that would make working on the car easier and probably safer too.
    Oddly enough I somehow feel like this is something the wife would actually support spending money on...
    Any clue what is a really good price on one?
    7xx to 8xx rwhp
    Pulley and tune
  23. #22
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    13,647
    Likes (Given)
    0
    Likes (Received)
    397
    I call BS (Given)
    0
    13
    $1300, 5000# cap and 22" lift
    679RWHP 662RWTQ
    BMF cam
    ID850's
    IW 9.1/2.55
    Norcal ice tank
  24. #23
    Active Member
    Join Date
    Jun 2012
    Location
    Spring/Woodlands TX
    Posts
    14,535
    Likes (Given)
    62
    Likes (Received)
    588
    I call BS (Given)
    0
    11
    Not bad. Assume that's new and they aren't on sale ever? Still...a good floor jack can run 200-300. And this is fully powered, which is so much better.
    7xx to 8xx rwhp
    Pulley and tune
  25. #24
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    13,647
    Likes (Given)
    0
    Likes (Received)
    397
    I call BS (Given)
    0
    13
    $1300 is on sale
    679RWHP 662RWTQ
    BMF cam
    ID850's
    IW 9.1/2.55
    Norcal ice tank
  26. #25
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    13,647
    Likes (Given)
    0
    Likes (Received)
    397
    I call BS (Given)
    0
    13
    $1300 is on sale,
    I like that you could take it to the race track etc.....
    I think it's cool, but for $700 you can get a full two post lift which would be far more functional in a garage set up.
    The max jax lift is fully portable as well.
    679RWHP 662RWTQ
    BMF cam
    ID850's
    IW 9.1/2.55
    Norcal ice tank
  27. #26
    Active Member
    Join Date
    Nov 2013
    Location
    Germantown,TN
    Posts
    624
    Likes (Given)
    0
    Likes (Received)
    12
    I call BS (Given)
    0
    2
    What is the name of the 2 post lift that's $700
    Cam, Meth, Headers, Dynospeed Tuned and all the supporting goodies.
  28. #27
    Active Member
    Join Date
    Mar 2012
    Location
    Dallas, TX
    Posts
    6,591
    Likes (Given)
    12
    Likes (Received)
    132
    I call BS (Given)
    1
    10
    There is a way to get it a bit cheaper (about $1,100 total) but im scared you guys will all jump on it and they'll stop the deal before i have the $$ to buy!!
  29. #28
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    13,647
    Likes (Given)
    0
    Likes (Received)
    397
    I call BS (Given)
    0
    13
    Sorry meant $700 more.......Max jax are about $2k
    679RWHP 662RWTQ
    BMF cam
    ID850's
    IW 9.1/2.55
    Norcal ice tank
  30. #29
    Active Member
    Join Date
    Feb 2014
    Location
    Florida
    Posts
    628
    Likes (Given)
    0
    Likes (Received)
    13
    I call BS (Given)
    0
    0
    Wow that sucks, worker at my shop was running his car up on some ramps and drove right past the edge. Smashed is ground effects/side moldings but the metal of the car was all fine luckily.
    The ranger quickjack is pretty cool for simplicity.
    2009 CTS-V A6 Sedan Black, 20" F14's, Eibach's, Lingenfelter 650hp kit, ID850, HTC Coated ARH 1.875" Headers w/cats, SW 3" Exhaust, Hptuners Pro
    Mod Pile, WxM Hood & Track Attack, Wiseco -15cc, K1 3.9 Crank, Eagle Rods ARP2000, GPTuning Cam, Mamo TFS Heads, LSA Block, NW102mm
  31. #30
    Active Member
    Join Date
    Oct 2016
    Posts
    490
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    Did you use this Quickjack 5000 on the V? If so where did you jack from? I am going to a friends house to use his to do the diff and trans fluids next week (and possibly brakes). I want to make sure that it does work on a CTSV Wagon/Sedan.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
Search tags for this page
ctsv headers on jack stands
jack points
quickjack cts
special jack stands that lift over 28 for auto only
