KillerChiller
Results 1 to 12 of 12
Like Tree3Likes
  • 2 Post By Karch
  • 1 Post By Lt1z
Thread: KillerChiller
  1. #1
    Active Member
    Join Date
    Aug 2013
    Location
    44.564673, -73.323766
    Posts
    155
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    I call BS (Received)
    0
    KillerChiller
    I'm still looking at interchiller options. KillerChiller has kits for CTSV's and others. Anyone here have experience with them? I emailed them, they claim it's plug-n-play with no hose modifications (can easily demod). I searched the forum, last mention was in 2015.
    2009.5 Passion Red Metallic G8 GT
    Experience is what you get when you didn't get what you wanted. -Pausch
  2. #2
    Active Member
    Join Date
    Aug 2016
    Location
    Stockton CA
    Posts
    105
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    You wont get alot of interchiller info on this forum, go on the zl1 forum they tend to be more popular on there, but they do work.
  3. #3
    Registered User
    Join Date
    Mar 2016
    Location
    MI
    Posts
    12
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Why is that? I am trying to learn more about these kits as well. I see a lot of posts and videos online of really low IAT2's at idle and cruising. I am curious how big of a difference there is on long pulls. Starting with a lower IAT should help I would think. They tell you to remove the hx with these kits and add as much capacity as you can. I am running a 2.4/9.1 pulley combo and am doing a half mile event the end of June. Trying to figure out the best way to keep my IATs under control. I currently have the lingenfelter hx, ZR1 pump, deleted hard lines, with the D3 expansion tank. Also have the ZL1 lid (more for looks than anything). I like the theory of being able to plummet my IAT temps while staging at the track and even for this half mile.
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Join Date
    Jul 2011
    Location
    Los Angeles
    Posts
    16,168
    Likes (Given)
    380
    Likes (Received)
    343
    I call BS (Given)
    10
    19
    Best method is methanol.
    Ross L and 12CoupeV like this.
  6. #5
    Active Member
    Join Date
    Sep 2014
    Location
    New Fairview, TX
    Posts
    172
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    As Karch said, best method is methanol injection, with straight methanol. Pre and post boost, in the CAI, and in the lid. The kit is half the price of the interchiller, and it gets the job done great! Hit up Rodney at ProMeth, he is a very knowledgeable guy, and he can get you hooked up for your setup.
    Attached Thumbnails Attached Thumbnails KillerChiller-img_0371.jpg KillerChiller-img_0372.jpg KillerChiller-img_0383.jpg
    2012 WD Coupe A6
    Stage 1 - Airraid CAI, Ported LS7, 2.4 Metco Pulley Kit with 100mm idler, FIC 1000's, DSteck Flex Sensor, FasterProms Tank, AFCO Low Mount HX, Varimax Pump, Mighty Mouse Catch Can, B&B Test Pipes, Custom 3" X pipe and catback with Spintech Mufflers
    Stage 2 - LS9 Cam, TSP 9.1 Lower, KB BAP, APR Splitter
    Stage 3 - removed B&B Test Pipes, added ARH 2" Headers, ProMeth Methanol Injection pre/post boost, Justin White Tuned
    Stage 4 - eventually...
  7. #6
    Active Member
    Join Date
    Aug 2016
    Location
    Stockton CA
    Posts
    105
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    Quote Originally Posted by 12CoupeV View Post
    What activates the meth on that kit? Map signal? Hobbs switch?
  8. #7
    Registered User
    Join Date
    May 2017
    Posts
    7
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    The pro meth kit looks like a very clean install.
  9. #8
    Join Date
    Mar 2012
    Posts
    273
    Likes (Given)
    16
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    Quote Originally Posted by Taylo708 View Post
    Best method is Active Interchiller, we have other customers going to that half mile. The reason they say lose the H/E is for room on the V2. We have an advanced bypass system but then you have to cut the bumper for Chiller to fit. You already have the the pump and reservoir for the best setup to add a Chiller. Our kit is the best value with nothing modified under hood! That same setup goes standing mile without pulling timing with our Chiller the original Interchiller.
  10. #9
    Join Date
    Mar 2012
    Posts
    273
    Likes (Given)
    16
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    GizmoQ and his XLR V fitted in 2012, running 20lb on a North star. This is after 30 minutes driving, people commented about this very sight when he opened the hood after running the Texas Mile!
    Texas Mile 10/27/12 853AM shakedown run.
    2013 St Louis Region SCCA Solo Super Street Modified Class Champion
    ECTA Land Speed Racing Record Holder: 4.2-5.0L Blown Gas Modified Sports Car
    Texas Mile Record Holder: Street Legal XLR @ 165.6MPH
    This car came in with IATs way over 200deg, it is internally geared to make 20lb boost and runs crazy hot. They are also known for not getting good cold air intake. TX mile was 126deg max with our 13” Chiller.
  11. #10
    Registered User
    Join Date
    Mar 2016
    Posts
    15
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    What makes the interchiller better than meth?
    What makes meth better than the interchiller?
  12. #11
    Join Date
    Mar 2012
    Posts
    273
    Likes (Given)
    16
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    Quote Originally Posted by 7camaro7 View Post
    I had Meth in 08 before the first Interchiller in 09 they work well together, I use 50/50. My local source Speed World moved away so it is harder for me to source now. Meth gives you octane but it takes large quantities to do the work of an Interchiller. I took an order today from a Forum Member with a V2 Heartbeat 850HP He said Meth was not cutting it here in FL. I installed Meth on the XLR V above at the same time as the Chiller, it’s very common to use both.
    Interchiller never needs to be refilled and as long as you use AC it cost nothing to use and prevents Heat Soak. Interchiller allows you to hot lap and makes a big difference on consistency. Intrchiller is passive for street use Meth only sprays under boost but like I said they work well together.
  13. #12
    Join Date
    Jul 2011
    Posts
    10,528
    Likes (Given)
    249
    Likes (Received)
    183
    I call BS (Given)
    0
    3
    Quote Originally Posted by George536 View Post
    When doing meth on these cars I use a MAF trigger rather then Map
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
