intercooler pump alternative.
Page 1 of 7 123 ... LastLast
Results 1 to 30 of 204
Like Tree57Likes
Thread: intercooler pump alternative.
  1. #1
    Active Member
    Join Date
    Nov 2013
    Location
    Hurst TX
    Posts
    942
    Likes (Given)
    0
    Likes (Received)
    7
    I call BS (Given)
    0
    I call BS (Received)
    0
    Ok all I posted something in a FS thread but figured since the pump sold it wouldn't get much traffic. After seeing the ZR1 pump FS thread it got me thinking and researching some. Here is what I have come up with and was wondering if anyone has look at this before. The ZR1 pump appears to be made by Pierburg out of Germany and after doing some digging looks to be almost the same as there CWA 50 pump. This pump is used in some newer BMW applications as well as hybrid setups like the Azure Transit Connect Electric as such it seems to be cheap you can find them on Ebay as well as other sites for 75-200.
    The data looks promising at just over 10 gpm at 5 psi. Here is a post over at another forum with a write up on the pump Intercooler Pump you didn't know about - Page 4 - MBWorld.org Forums. If this data is correct it may be a vary interesting alterntive at a cheaper price of course some wiring will have to be done to get it all working. Also the CAW-100.2 used on some MB AMG's as a tras cooler pump could also be used. Thoughts?
    Wrecked Em likes this.
  2. #2
    Active Member
    Join Date
    May 2014
    Posts
    271
    Likes (Given)
    0
    Likes (Received)
    5
    I call BS (Given)
    0
    1
    Sub'd
    Sent from my LG-H810 using Tapatalk
  3. #3
    Active Member
    Join Date
    Dec 2011
    Location
    Chicago
    Posts
    1,911
    Likes (Given)
    0
    Likes (Received)
    30
    I call BS (Given)
    0
    1
    I dont know anything about the German one's but LPE did a comparison of some of the GM options.
    Intercooler pump flow testing results
    '13 BD coupe - Hawk-Moroso-Airaid-IDs-TaHx-Varimax-MSD-NGK-Kooks Catless-irish'd ZL1 lid-ATI w/10" lower-Mamo LS7.
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Active Member
    Join Date
    Oct 2012
    Location
    Porter Ranch
    Posts
    1,333
    Likes (Given)
    32
    Likes (Received)
    51
    I call BS (Given)
    4
    1
    I went ahead and bought the EMP on ebay for $300. They come up often...
  6. #5
    Active Member
    Join Date
    Nov 2013
    Location
    Hurst TX
    Posts
    942
    Likes (Given)
    0
    Likes (Received)
    7
    I call BS (Given)
    0
    0
    Quote Originally Posted by CoppeR View Post
    I don't know anything about the German one's but LPE did a comparison of some of the GM options.
    If you look at the CWA-50 pump data it looks to match the ZR1 pump at 5 psi and can be had for 75-200 hell 280 from a BMW dealer. BMW part number 17122284291 the CWA-100.2 can be had for about 400 from MB part number 0005000486. If I can find a CWA-50 for 100 I'm thinking I'll be the guinea pig on this one and try it out.
  7. #6
    Join Date
    Jul 2011
    Location
    Los Angeles
    Posts
    15,828
    Likes (Given)
    377
    Likes (Received)
    334
    I call BS (Given)
    10
    19
    Thanks for the info. That CM90 looks pretty good.
    Sent from my local E85 station.
  8. #7
    Active Member
    Join Date
    Mar 2015
    Posts
    2,181
    Likes (Given)
    0
    Likes (Received)
    41
    I call BS (Given)
    0
    3
    Sub'd for more info. Nice research!
    09' Thunder Gray Chroma Sedan | 6AT | UltraView | Eibach Springs | Velgen VMB5's
    "Factory Freak"
    Mod Pile reaching Critical Mass
  9. #8
    Active Member
    Join Date
    Nov 2013
    Location
    Hurst TX
    Posts
    942
    Likes (Given)
    0
    Likes (Received)
    7
    I call BS (Given)
    0
    0
    Quote Originally Posted by Karch View Post
    Didn't even look at the price of them till just now it's looking better now.
  10. #9
    Join Date
    Jul 2011
    Posts
    10,314
    Likes (Given)
    242
    Likes (Received)
    181
    I call BS (Given)
    0
    3
    The Pierburg the 13-14 GT500 comes with is nice too and can be had for $275 or so
    http://www.tascaparts.com/oe-ford/dr3z8501a
    VVVROOMTX likes this.
  11. #10
    Active Member
    Join Date
    Nov 2013
    Location
    Hurst TX
    Posts
    942
    Likes (Given)
    0
    Likes (Received)
    7
    I call BS (Given)
    0
    0
    Quote Originally Posted by Lt1z View Post
    AUX PUMP | Genuine Ford | DR3Z-8501-A
    Yep this looks like the exact same as the CWA-50.
    http://www.ebay.ca/itm/141477665400
  12. #11
    Join Date
    Jul 2011
    Posts
    10,314
    Likes (Given)
    242
    Likes (Received)
    181
    I call BS (Given)
    0
    3
    Quote Originally Posted by ASteggall View Post
    Yes it does and the ford harness can be cut and spliced into the factory or any other harness setup for the Bosch pump.
  13. #12
    Active Member
    Join Date
    Oct 2011
    Location
    Langley, BC
    Posts
    446
    Likes (Given)
    2
    Likes (Received)
    2
    I call BS (Given)
    2
    1
    According to the flow/pressure spec's on the item listing, that pump is no better than the stock one.
  14. #13
    Join Date
    Jul 2011
    Posts
    10,314
    Likes (Given)
    242
    Likes (Received)
    181
    I call BS (Given)
    0
    3
    Quote Originally Posted by Wetcoast View Post
    The one from the GT500 13-14 models flows just about the same at the ZR1 pump. The 09-12 GT500 uses the same Bosch pump a ctsv comes with.
  15. #14
    Active Member
    Join Date
    Feb 2013
    Posts
    8,367
    Likes (Given)
    1062
    Likes (Received)
    295
    I call BS (Given)
    18
    18
    Just let me know when you guys do all the legwork so I know what to buy.... lol
    LBZRCKS and TripleWhite96 like this.
    Please enjoy my personal testing of common performance modifications, and as always: your mileage may vary!
    Comparison Threads:
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
  16. #15
    Active Member
    Join Date
    Feb 2014
    Location
    Florida
    Posts
    628
    Likes (Given)
    0
    Likes (Received)
    13
    I call BS (Given)
    0
    0
    I picked one up since I could use a better a pump to go with the track attack but it will be a while before I get around to installing it.
    2009 CTS-V A6 Sedan Black, 20" F14's, Eibach's, Lingenfelter 650hp kit, ID850, HTC Coated ARH 1.875" Headers w/cats, SW 3" Exhaust, Hptuners Pro
    Mod Pile, WxM Hood & Track Attack, Wiseco -15cc, K1 3.9 Crank, Eagle Rods ARP2000, GPTuning Cam, Mamo TFS Heads, LSA Block, NW102mm
  17. #16
    Active Member
    Join Date
    Nov 2013
    Location
    Hurst TX
    Posts
    942
    Likes (Given)
    0
    Likes (Received)
    7
    I call BS (Given)
    0
    0
    Just another graph I came across. Kinda hard to read.
  18. #17
    Active Member
    Join Date
    Mar 2013
    Location
    Chandler, AZ
    Posts
    201
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    Sub'd
  19. #18
    Active Member
    Join Date
    Nov 2014
    Location
    Fredericksburg TX
    Posts
    131
    Likes (Given)
    0
    Likes (Received)
    5
    I call BS (Given)
    0
    0
    Sub'd
    2009 CTS-V Radiant Silver. Mont Motorsports 4in intake, SMC CC, Weapon X Radiator.
  20. #19
    Active Member
    Join Date
    Mar 2015
    Posts
    1,899
    Likes (Given)
    0
    Likes (Received)
    54
    I call BS (Given)
    0
    0
    I shall award 3 Internets to the first person with install and feedback.
    Detroit_Muscle likes this.
    2012 CTS-V Coupe 6MT - 4.5"/102 combo, fully ported blower, TEA Stg2 LSA heads, LT1Z Stg 2.5 cam, SW 2" Catless, 2.5/9.1 pullies, -10 ZL1 lid, ID850's, TA+low mount, Varimax, Norcal, etc. Tuned by Mike @ New Era. Labor by New Era Performance. 720 hp & 659tq
    APRIL 2017: DSX Aux Pump, DSX Flex Sensor, ID1000's & Corsa Touring. Installed @ Weapon X Motorsports. Tuned by Jeremy@WXM - 708whp on pump - 758 on E58
  21. #20
    Active Member
    Join Date
    Mar 2014
    Location
    Fairfield CA
    Posts
    311
    Likes (Given)
    0
    Likes (Received)
    6
    I call BS (Given)
    0
    0
    The ZR1 pump is expensive but other than making a bracket it is plug n play including the electrical connector. Only "down side" which doesn't even bother me is it is kinda loud.
    2013 Thunder grey A6 CTS-V sedan - 775/726 on e85
    2011 Thunder Grey A6 CTS-V coupe - sold
  22. #21
    Active Member
    Join Date
    Mar 2014
    Posts
    461
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    Quote Originally Posted by Bullitt4110 View Post
    I think the point the OP is making is that this may be an alternative to the ZR1 pump at a fraction of the cost.
    edit: I typed Zl1 (junk) instead of ZR1.
  23. #22
    Active Member
    Join Date
    Mar 2015
    Posts
    1,899
    Likes (Given)
    0
    Likes (Received)
    54
    I call BS (Given)
    0
    0
    That gt500 pump has my attention. ZR1 flow for 1/4 the cost.
  24. #23
    Active Member
    Join Date
    Nov 2013
    Location
    Hurst TX
    Posts
    942
    Likes (Given)
    0
    Likes (Received)
    7
    I call BS (Given)
    0
    0
    Quote Originally Posted by Detroit_Muscle View Post
    I think the point the OP is making is that this may be an alternative to the ZL1 pump at a fraction of the cost.
    Close. I am seeing it as an alternative to the ZR1 pump.
    Sent from my XT1254 using Tapatalk
    ID850's, 2.4 upper, Track Attack HX, Varimax pump, ZL1 Lid, Texas Speed headers, Airaid with green filter, Moroso catch can, LPE tank, PLX wideband, tuned by Pat G.
  25. #24
    Active Member
    Join Date
    Sep 2014
    Location
    Florida Keys
    Posts
    794
    Likes (Given)
    5
    Likes (Received)
    23
    I call BS (Given)
    3
    0
    I can get Johnson, FloJet and Jabsco at cost FYI
    14 RB Vagon 626/621 on E49 10.65@128.9
    Norcal Icebox, Varimax, Track Attack, 3/4 hose mod, Airaid/Green filter, Mamofied TB, Sideswipe
    Moroso Catch Can, Ported Blower/Snout, 2.4, 100mm idler, D Steck Flex Fuel with aux filter, Kooks LTs catless
    FIC 1000, 160 stat, BR7EF plugs, MSD Wires, Fasterproms Thermal Plates, Reinforced brick, Aeroforce in dash w/wideband.
  26. #25
    Join Date
    Jul 2011
    Location
    Los Angeles
    Posts
    15,828
    Likes (Given)
    377
    Likes (Received)
    334
    I call BS (Given)
    10
    19
    Quote Originally Posted by Boatmangc View Post
    Can you let me know a price on a Johnson CM90? This would be the 12V variety.
    Thank you.
  27. #26
    Active Member
    Join Date
    Sep 2014
    Location
    Florida Keys
    Posts
    794
    Likes (Given)
    5
    Likes (Received)
    23
    I call BS (Given)
    3
    0
    Thank you.
    I will check it out when I get done tonight, 1st day of Lobster season today, gonna be a gauntlet...
    Karch likes this.
  28. #27
    Active Member
    Join Date
    Mar 2015
    Posts
    2,181
    Likes (Given)
    0
    Likes (Received)
    41
    I call BS (Given)
    0
    3
    Has anybody actually got the 13+ GT500 pump and tried it out?
    "Factory Freak"
  29. #28
    Active Member
    Join Date
    Sep 2014
    Location
    Florida Keys
    Posts
    794
    Likes (Given)
    5
    Likes (Received)
    23
    I call BS (Given)
    3
    0
    I talked to my sales rep about the Johnson pump.
    To be sure we are talking about 3/4" hose with mounting bracket?
    I have options with or without the bracket an also 1 1/2" hose.
    I'm asking about case prices in case a few members are interested.
    random84 likes this.
  30. #29
    Active Member
    Join Date
    Nov 2013
    Location
    Hurst TX
    Posts
    942
    Likes (Given)
    0
    Likes (Received)
    7
    I call BS (Given)
    0
    0
    Quote Originally Posted by VVVROOMTX View Post
    Not yet, but looking at trying it sometime soon.
    The 3/4 version, I would think 1 1/2 would be a little overkill. As for the bracket not sure I would say with I mean the price can't be that much more.
  31. #30
    Join Date
    Jul 2011
    Location
    Los Angeles
    Posts
    15,828
    Likes (Given)
    377
    Likes (Received)
    334
    I call BS (Given)
    10
    19
    Definitely the 3/4" version.
    If I get one, I'll try to test it out with a ZR1 and EMP pump and report back, but I need to find a HX to use for bench testing.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
Search tags for this page
cts v supercharger pump
ctsv intercooler pump
cwa 100 pump psi
cwa 50
cwa 50 pump
flow of 3 bosch pumps vs zr1 pump
gt500 hx pumps ctsv
gt500 pierburg cwa 50
pierburg intercooler pump mercedes
what is the connector used on cu2z-14s411-apa
zr1 intercooler pump
zr1 intercooler pump best pump
