dang the noise
Results 1 to 6 of 6
Thread: dang the noise
  1. #1
    Active Member
    Join Date
    Jul 2015
    Posts
    86
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    I call BS (Received)
    0
    dang the noise
    I've put over 40k miles on my car over that past two years I've had her. its always had some slight growl at sharp turns with a cold diff. its always went away after warmed up. lately it has been getting worse so I decided to do a lube change. I went with royal purple 75w90 with additive since its the best I could find locally. that was 4 days ago so 400 miles roughly. today leaving to get some lunch it was very loud and rough feeling.
    i ordered the ac delco additive as soon as i got back in from lunch. my plan is to add some and see where we are after that. does anybody see an issue using it with the RP fluid that supposedly already has an additive? maybe next will be to step up to 75w140 fluid?
  2. #2
    Active Member
    Join Date
    Jun 2016
    Posts
    65
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    You should be ok with adding it.
  3. #3
    Active Member
    Join Date
    Aug 2013
    Location
    NorCal
    Posts
    2,148
    Likes (Given)
    53
    Likes (Received)
    77
    I call BS (Given)
    14
    4
    I've had no issue with Redline fluid in any of my vehicles.
    Royal purple seems to have a few for some reason.
    2011 CTS-V
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Active Member
    Join Date
    Jul 2011
    Location
    Johns Creek Georgia
    Posts
    207
    Likes (Given)
    0
    Likes (Received)
    6
    I call BS (Given)
    0
    0
    Mine only has right at 12k miles and had the same noise when cold but changed the fluid and used the GM stuff and all is well!
  6. #5
    Active Member
    Join Date
    Sep 2014
    Location
    South Florida
    Posts
    57
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Try after the diff and fluid is warmed up going in circles in a parking lot. Do maybe 10-15 one way and then the other direction to help get the fluid worked into the clutches. I had to do that all the time with Vettes and AWD minivans that had whining rear diffs, had to go in circles until dizzy and then keep going lol.
  7. #6
    Active Member
    Join Date
    Jul 2015
    Posts
    86
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    the additive seemed to do the trick. i have just a slight noise that i wouldn't notice if i knew nothing of these issues.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
