Wideband O2
Results 1 to 20 of 20
Like Tree2Likes
  • 1 Post By Eleventeen
  • 1 Post By CypressV
Thread: Wideband O2
  1. #1
    Jim
    Jim is online now
    Active Member
    Join Date
    Dec 2016
    Location
    Roswell, NM
    Posts
    66
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    I call BS (Received)
    0
    Wideband O2
    I'm getting some mods ready for installation soon and have been shopping for wideband controllers and was curious to know if anyone is using Innovates 3877 controller. It is the LC-2 controller without a gauge. I have HP Tuners and will be connecting the controller to the interface for scanning. Is there really a need for a separate gauge? I prefer to keep the stock "look" and while I know that the gauge can be mounted out of sight in either the glove box or center console near the 12 volt outlet, I doubt that I would use it. I searched and found a few using the LC-2 with the gauge but didn't find any using it without.
    When I'm logging, I rely on the scanner and I typically run a log to and from work a few times a week or at least I did with my last car. If I don't run them as often with the V, I'll most likely run a new log shortly after filling the tank.
    Thanks!
  2. #2
    Active Member
    Join Date
    Sep 2014
    Location
    Midwest
    Posts
    2,705
    Likes (Given)
    0
    Likes (Received)
    79
    I call BS (Given)
    0
    0
    I have the innovate MTX-L that I also connect and log with HPT. My guage is mounted in the glove box and I may have looked at it 5x in a year.
    2009 6MT - 708hp E63CORN-634hp/637tq 93 octane - stock cam-- 2.5/91 - ported blower/snout/90mm LS7 Mamo TB - Track Attack HX - Norcal Ice box - FIC 1000 - JMS BAP- Dsteck FF - MM catch can - ZL1 lid - AirAid Green Filter - pocket protector/side swipe-Kooks 1 7/8 Headers - 22in resonators - SW catback
  3. #3
    Jim
    Jim is online now
    Active Member
    Join Date
    Dec 2016
    Location
    Roswell, NM
    Posts
    66
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Thanks! Looking forward to getting a few mods done and will probably call it good shortly before I sell the car in a few years....
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Active Member
    Join Date
    Aug 2013
    Location
    44.564673, -73.323766
    Posts
    153
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    Have a look at the aem 30-0333. It outputs to the canbus, no worries about DC offset - and very fast. Several posts on hp tuners forum detailing it.
    2009.5 Passion Red Metallic G8 GT
    Experience is what you get when you didn't get what you wanted. -Pausch
  6. #5
    Join Date
    Jul 2011
    Location
    Los Angeles
    Posts
    15,479
    Likes (Given)
    365
    Likes (Received)
    327
    I call BS (Given)
    10
    19
    Ballenger's wideband is the one most often recommended by tuners on this forum.
    I had an MTX in my TBSS and it failed after 2 years.
    Sales@dynamicflowconcepts.net
    Dynamicflowconcepts.net
  7. #6
    Active Member
    Join Date
    Nov 2014
    Location
    NYC
    Posts
    109
    Likes (Given)
    25
    Likes (Received)
    2
    I call BS (Given)
    1
    0
    I have innovate LC-2 Digital Wideband and it also connects to Aero Force gauge. $179 frm Mont Motor sports.
  8. #7
    Jim
    Jim is online now
    Active Member
    Join Date
    Dec 2016
    Location
    Roswell, NM
    Posts
    66
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Thanks to all. I picked up the LC-2 controller with sensor and no gauge. I'll get it installed first and then move on to the rest of the mods. I also picked up the B&B test pipes which show to have 2 bungs welded to them already. Are these bungs in the proper location for the installation of the sensor or do I need to weld an additional bung in? I've read that the sensor (when you're using just one) needs to be in the passenger side pipe and would assume that the top bung would be the proper one to use assuming it's in the right location.
    Thanks again!
  9. #8
    Active Member
    Join Date
    May 2015
    Location
    Dallas Ga
    Posts
    559
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    You will need to weld a bung
  10. #9
    Active Member
    Join Date
    Oct 2012
    Location
    Porter Ranch
    Posts
    1,309
    Likes (Given)
    31
    Likes (Received)
    48
    I call BS (Given)
    4
    1
    Go with the Ballenger. Innovate isn't great for tuning but if you want it for a reference then it works.
  11. #10
    Jim
    Jim is online now
    Active Member
    Join Date
    Dec 2016
    Location
    Roswell, NM
    Posts
    66
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Quote Originally Posted by Jchastain View Post
    Thanks for the heads up. I'll weld one in each pipe just in case.
  12. #11
    Join Date
    Oct 2014
    Location
    Panama City Beach, FL
    Posts
    1,568
    Likes (Given)
    5
    Likes (Received)
    26
    I call BS (Given)
    0
    0
    We offer a few options; Ballenger, Innovate, AEM, etc.
    Ballenger would be our first choice, followed by Innovate & AEM. If you just want a controller with no gauge, LC-2 is a good option for the price.
  13. #12
    Join Date
    Jul 2011
    Posts
    10,155
    Likes (Given)
    230
    Likes (Received)
    179
    I call BS (Given)
    0
    3
    Ballenger is probably the best on a budget...
    Almost any will work for monitoring to see if things are out of line.
  14. #13
    Active Member
    Join Date
    May 2015
    Location
    Dallas Ga
    Posts
    559
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    Quote Originally Posted by Jim View Post
    Make sure you test fit the 02 before welding the bung. You want to make sure you have access to install/remove it without having to remove the test pipe
    12' A6, 2.5/9.1, Btr stage 2 cam, 2" tsp catless headers, Fic 850's, jokerz ported stock tb, Dms reinforced brick, airaid with green filter, moroso cc, Bmr underhood icebox, Ta hx, varimax pump, eibach sedan springs, aem 30-0333 wideband.
  15. #14
    Active Member
    Join Date
    Jan 2015
    Location
    Toronto, ON
    Posts
    2,390
    Likes (Given)
    141
    Likes (Received)
    67
    I call BS (Given)
    7
    2
    I think it needs to be as close to the header collector/manifold end as possible. The angle of attachment is important as well.
    2009 CTS V Black Raven Sedan, M6, Recaro's, Ultraview
    Stage 0.6 Airaid CAI, Kooks 1 7/8" LT's, Kooks catted xpipe, stock mufflers, Mamofied LS7, NGK TR6, SM Dual CC, 160F stat, Dynojet tuned by Dave @dasilvamotorsport, SAE 526hp/508tq/91oct
  16. #15
    Active Member
    Join Date
    Mar 2014
    Location
    South Jersey
    Posts
    742
    Likes (Given)
    0
    Likes (Received)
    12
    I call BS (Given)
    0
    4
    Thanks again!
    Since you're removing the cats, you can just delete the rear O2 sensors and turn off the codes. The WB sensor can go in the rear bung, unless you prefer a different spot. It doesn't need to be right behind the collector (and shouldn't be put that close due to the excessive temps), but the further away you put it, the slower the response. The secondary O2 position should work fine, provided the angle is between about 15-80 degrees from vertical.
    12CoupeV likes this.
  17. #16
    Jim
    Jim is online now
    Active Member
    Join Date
    Dec 2016
    Location
    Roswell, NM
    Posts
    66
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Quote Originally Posted by Eleventeen View Post
    Awesome! That sounds easy enough.
    Thanks!
  18. #17
    Active Member
    Join Date
    Dec 2013
    Location
    Red Deer Ab.
    Posts
    224
    Likes (Given)
    0
    Likes (Received)
    5
    I call BS (Given)
    0
    0
    Quote Originally Posted by jcmgt View Post
    X2 that. Simple , even for me.
    ____________
    ZL1 9.85@140.88
  19. #18
    Active Member
    Join Date
    Jan 2015
    Location
    Cypress TX
    Posts
    60
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    FYI AEM released a clamp on style bung. No welding required. Clamp, drill hole and install sensor.
    2013 TG Sedan A6. Pulleys,Exhaust,Cam and Corn.
  20. #19
    Active Member
    Join Date
    Mar 2016
    Location
    Hobbs, NM
    Posts
    89
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    When you guys are using the Ballenger wideband, are you using the stock Bosch sensor that it comes with or do you upgrading to the NTK?
  21. #20
    Join Date
    Jul 2011
    Location
    Los Angeles
    Posts
    15,479
    Likes (Given)
    365
    Likes (Received)
    327
    I call BS (Given)
    10
    19
    Quote Originally Posted by bfhawk View Post
    NTK.
    Lmk if you need to buy one.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
Search tags for this page
wideband o2 cts-v
