Dual Map Conversion
Results 1 to 23 of 23
  1. #1
    Active Member
    Join Date
    Mar 2012
    Location
    Upland, CA
    Posts
    1,589
    Likes (Given)
    1
    Likes (Received)
    2
    I call BS (Given)
    0
    I call BS (Received)
    0
    Dual Map Conversion
    Ive done some searching. Anyone have an idea which pin on the ECU is utilized to make this happen?
    2003 BMW E39 M5; Ti Silver (Vortech V3; Air/Water Intercooled & Meth. Injected)
    1997 BMW E36 M3 Coupe; Arctic Silver; Caged Track Rat-2,600lbs
    2012 CTS-V Sedan; Thunder Gray Sold...But Never forgotten
    LSx B15; 1.9 Eaton; 9.17/2.55; LS9 Cam; LS3 TB; Kooks w/o CATS; id850's;
    640/602 Dyno Jet
    Hidden Content
  2. #2
    Active Member
    Join Date
    Dec 2012
    Location
    Camas, WA
    Posts
    144
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    I would love to know this info also.
    I would bet with just E40 we could get full hp tuning. I love true flex fuel cars. Dual maps sucks.
  3. #3
    It's got an intake tube!
    Join Date
    Jan 2012
    Location
    State of Confusion
    Posts
    7,948
    Likes (Given)
    572
    Likes (Received)
    224
    I call BS (Given)
    28
    21
    Bubbs knows how. I threw the question at him.
    2011 White Diamond Sedan A6, 10.7 @ 130 (stage 1)
    750 RWHP (138ish through the trapper) So far... (stage 2)
    Click here -> Hidden Content
    Hidden Content
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Active Member
    Join Date
    Mar 2012
    Location
    Upland, CA
    Posts
    1,589
    Likes (Given)
    1
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    As I understand it, is a matter of rigging a simple switch with 12v power to it, the other pole goes to a pin on the ECU....
  6. #5
    Join Date
    Jan 2012
    Location
    State of Confusion
    Posts
    7,948
    Likes (Given)
    572
    Likes (Received)
    224
    I call BS (Given)
    28
    21
    Have you experimented with the flex fuel Option in the tune with the diminishing stoich? I don't know about kali, but here the alky content varies per summer or winter...
    Hidden Content
  7. #6
    Active Member
    Join Date
    Mar 2012
    Location
    Upland, CA
    Posts
    1,589
    Likes (Given)
    1
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    No, not gonna mess with that at all. Im going to establish a whole seperate map to run straight race gas/methanol. I already have a "high octane" tune due to the torco/meth day-to-day blend. I have found that when I race, i'm running race gas anyway because of my phobia about detonation due to bad fuel.
  8. #7
    Join Date
    Jan 2012
    Location
    State of Confusion
    Posts
    7,948
    Likes (Given)
    572
    Likes (Received)
    224
    I call BS (Given)
    28
    21
    Steve, I'm very interested in this too. I'm curious as to how you program a second calibration.
    Hidden Content
  9. #8
    Active Member
    Join Date
    Mar 2012
    Location
    Upland, CA
    Posts
    1,589
    Likes (Given)
    1
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    Saw your post over "there". Shaun Church has indicated that any switch to 12v power, other pole goes to an ECU pin. I have ben searching and have yet to find which pin the pole gets connected to. I'll keep you posted.
    EFI Live has a seamless ability apparently to do the tune...
  10. #9
    Active Member
    Join Date
    Nov 2012
    Location
    Houston, Tx
    Posts
    448
    Likes (Given)
    2
    Likes (Received)
    0
    I call BS (Given)
    1
    0
    In the diesel community we were able to us EFI Live and switch between 5 different tunes on the fly. Used a 5 position switch with different resistors and then loaded each tune. If someone can find out what ECU pin then you should be able to run the same set-up as the Duramax.
  11. #10
    Join Date
    Oct 2011
    Location
    OC, CA
    Posts
    2,916
    Likes (Given)
    1
    Likes (Received)
    103
    I call BS (Given)
    0
    5
    I think if you search for E67 software on the EFIlive forum it has directions.
  12. #11
    Active Member
    Join Date
    Mar 2012
    Location
    Upland, CA
    Posts
    1,589
    Likes (Given)
    1
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    Tabio I have looked, but unable to find on the efi live forum....Can you provide better direction?
  13. #12
    Banned
    Join Date
    Mar 2013
    Location
    Cypress, Texas
    Posts
    1,574
    Likes (Given)
    12
    Likes (Received)
    14
    I call BS (Given)
    3
    11
    Update? Me and my tuners were talking about this today. He has not found the right pin yet either for this PCM.
  14. #13
    Active Member
    Join Date
    Jan 2012
    Location
    Minneapolis
    Posts
    1,015
    Likes (Given)
    67
    Likes (Received)
    14
    I call BS (Given)
    3
    1
    2011 Raven CTS-V A6 Sedan
    Hidden Content
    10 / 2.85, 4.5" WXM/DynoSpeed Intake, Sideswipe, Pocket Protector, SW Headers / Testpipes, Ported Snout & LS7 90mm TB, ID850's, Alky Meth, Norcal IceBox, ZL1 Lid, Tabio Phenolic Lid Spacer, Fluidyne HX, Jabsco pump, 609hp/620tq (Update Pending)
    Stage 3 Pending - Heads / Cam going into mod pile soon
    Tuned by Carl@CJ Tunes
  15. #14
    Banned
    Join Date
    Mar 2013
    Location
    Cypress, Texas
    Posts
    1,574
    Likes (Given)
    12
    Likes (Received)
    14
    I call BS (Given)
    3
    11
    Quote Originally Posted by Mr. GoodCad View Post
    Yup I think so!
  16. #15
    Active Member
    Join Date
    Mar 2012
    Location
    Upland, CA
    Posts
    1,589
    Likes (Given)
    1
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    1INSANEV, you are fortunate that you have an 09. On my 2012, there is no "OS Load" Bottom line on your 09, you should be good to go.
  17. #16
    Banned
    Join Date
    Mar 2013
    Location
    Cypress, Texas
    Posts
    1,574
    Likes (Given)
    12
    Likes (Received)
    14
    I call BS (Given)
    3
    11
    Hava read that thread. They are flashing the PCM to the 2009's and it works.
    On another note..... This is a not so useful set up since it is a switch that goes from full pump gas to straight e85 tune via a switch. Whereas we want to be able to interpolate between the various ethanol tables according to the ethanol content of the mixture in the tank.
    In order to wire in and get the flex fuel sensor to work we need to know which E67 ECU pinout will read the sensor frequency and duty cycle and apply it to the tables.
    Like the Haltech setup
  18. #17
    Join Date
    Aug 2011
    Location
    Austin, TX
    Posts
    3,712
    Likes (Given)
    56
    Likes (Received)
    172
    I call BS (Given)
    0
    2
    I'm working on it.
  19. #18
    Banned
    Join Date
    Mar 2013
    Location
    Cypress, Texas
    Posts
    1,574
    Likes (Given)
    12
    Likes (Received)
    14
    I call BS (Given)
    3
    11
    Quote Originally Posted by DSteck View Post
    I'm working on it.
    Ok keep me in mind I should be ready to tune in 1.5 weeks, ready set go!
  20. #19
    Join Date
    Aug 2011
    Location
    Austin, TX
    Posts
    3,712
    Likes (Given)
    56
    Likes (Received)
    172
    I call BS (Given)
    0
    2
    I'm glad I'm going to do all the hard work so people can get a free ride. Lol.
    FML
  21. #20
    Banned
    Join Date
    Mar 2013
    Location
    Cypress, Texas
    Posts
    1,574
    Likes (Given)
    12
    Likes (Received)
    14
    I call BS (Given)
    3
    11
    It's all for the cause brother
  22. #21
    Banned
    Join Date
    Mar 2013
    Location
    Cypress, Texas
    Posts
    1,574
    Likes (Given)
    12
    Likes (Received)
    14
    I call BS (Given)
    3
    11
    Well seeking out the info and it was released by lsxworks today.
    Total of $119.00 parts shipped sensor, fittings, harness etc. however the harness is on backs order smh
    C1 Pin 5.
    http://forum.efilive.com/showthread....requency-input
  23. #22
    Join Date
    Aug 2011
    Location
    Austin, TX
    Posts
    3,712
    Likes (Given)
    56
    Likes (Received)
    172
    I call BS (Given)
    0
    2
    http://www.hptuners.com/forum/showth...8-E67-addition
    I got harnesses no problem. $67.00 is the total cost of parts for me.
  24. #23
    Banned
    Join Date
    Mar 2013
    Location
    Cypress, Texas
    Posts
    1,574
    Likes (Given)
    12
    Likes (Received)
    14
    I call BS (Given)
    3
    11
    Hate. You lol. I will buy the harness from you! Ya but I had to get 6an fittings + shipping.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
