GM Special Coverage Adjustment Supercharger Warranty Extension - Page 5
Page 5 of 5 FirstFirst ... 345
Results 121 to 139 of 139
Like Tree16Likes
Thread: GM Special Coverage Adjustment Supercharger Warranty Extension
  1. #121
    Active Member
    Join Date
    Jun 2012
    Location
    Spring/Woodlands TX
    Posts
    14,515
    Likes (Given)
    62
    Likes (Received)
    588
    I call BS (Given)
    0
    I call BS (Received)
    11
    Quote Originally Posted by ASteggall View Post
    ^^This. Not to mention the hermonic was mostly on the M6 cars. On the A6 cars just drive like you got a pair and problem solved.
    Right on...mod up and quit crying lol!!!
    Quote Originally Posted by Admiral Ballsy View Post
    Original owner.
    There are plenty of guys with ZL1s earlier than my car with the solid piece. It's plausible that Eaton shipped to GM in a non-FIFO manner.
    I hardly "got lucky", though. The solid piece is borderline undriveable if you have a manual.
    You just got 28 TriTexan Bonus points for using FIFO.
    2014 OBM/Titanium CTS-V Wagon "The Blue Whale"
    Auto, All Options, Interior 100% stock.
    Custom touches here and there...needs driver mod badly!
    7xx to 8xx rwhp
    2015 Audi SQ5 Prestige Glacier White Metallic + Gloss Piano Black trim "Snow White"
    Black leather interior, 8 Spd ZF Auto, all options
    Pulley and tune
    21" RS6 wheels /Super Sport 285's all around / Lowered on KW's
  2. #122
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    13,637
    Likes (Given)
    0
    Likes (Received)
    397
    I call BS (Given)
    0
    13
    Just going to say GM typically works on JIT and FIFO as the norm. Might not be chronological order, but within a few days stock.
    No way would they have 3 month old product on a plant shelf.
    679RWHP 662RWTQ
    BMF cam
    Ported SC/Snout/90TB
    Kooks LT w/cats stock muffs
    ID850's
    IW 9.1/2.55
    Airaid w/green filter
    Katech+W4M HX ZR1 pump
    Norcal ice tank
  3. #123
    Active Member
    Join Date
    Nov 2015
    Location
    Warren, MI
    Posts
    825
    Likes (Given)
    30
    Likes (Received)
    11
    I call BS (Given)
    0
    2
    I can't speak for the general assembly area of the facility (LGR for us, IIRC) but I have ABSOLUTELY seen body shops build out cars with 2-3 month old metal.
    I won't go so far as to say they've made it out the door that way, and it wasn't specifically LGR I worked with, but we're not perfect about FIFO.
    It can be very obvious when it's split in areas that have long since been addressed or they're trying to hem aluminum that was stamped more than 60 days ago (has to be hemmed within 60 days or the aluminum ages too much and cracks along the hemmed edge).
    Edit: I shouldn't have said "build out", that implies they became finished vehicles. But the panels were absolutely run thru their respective body shop cells and physically hung on a vehicle before being eventually noticed.
    2012 BDT Sedan - Recaro's, Ultraview, A6 >Hidden Content <
    Stg 1 (as-purchased): Airaid, EE catchcan, 2.4" Metco, TR7IX, ported snout, Mamo LS7 TB, ID850's, ARH 1 7/8", Vadder Destroyer HX & CWA50 pump, ZL1 lid- 560rwhp/530rwtq SAE
    Stg 1.5: DMS (Flex)Fuel Trio, reinforced brick and Black Moon Aero- TBD
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #124
    Active Member
    Join Date
    Jun 2012
    Location
    Spring/Woodlands TX
    Posts
    14,515
    Likes (Given)
    62
    Likes (Received)
    588
    I call BS (Given)
    0
    11
    Quote Originally Posted by 94383Z71 View Post
    I think the financial penalties/consequences of inventory deter most large mfgs from keeping anything around long. As LA noted JIT parts are the order of the day nowadays.
    7xx to 8xx rwhp
    Pulley and tune
  6. #125
    Active Member
    Join Date
    Nov 2015
    Location
    Warren, MI
    Posts
    825
    Likes (Given)
    30
    Likes (Received)
    11
    I call BS (Given)
    0
    2
    Quote Originally Posted by TriTexan View Post
    I'm aware of how JIT fits in- I was working at a semi-contiguous stamping plant where every morning at 9:30 we met to discuss how assembly performed the day before compared to projections, and vice versa for how many good parts we were able to get to them.
    Doesn't change how obvious it is when they're trying to run aluminum that's past its hem-by date, and it would have hit their inventory within 7 of the 60 days they have to use it.
    Again, I'm not going to say that proves anything about S/C isolators, but fact of the matter is it is still human beings scheduling material/parts to their facility, unloading/storing them, and eventually getting them to the line. I know bodyshop can screw it up to the tune of 2mo old materials, so it wouldn't surprise me in GA is all.
    Edit: I've been thinking and I could make this clearer.
    When assembly orders from us, they order in 'packs' that are loosely figured around daily assy counts (+ safety margins for truck/rack/road damage, etc). For us, a pack was ~300 parts, and most days were 1-2 packs. They also required a minimum of two packs more than projections called for, in reserve.
    Being contiguous, we had access to their parts inventory database. I can't even tell you how often we would have to REFUSE to make 300-1000 pieces of a panel because their inventory clearly showed they had enough for several days, because we needed that press time to make panels they really didn't have enough of. It was clear their ordering personnel were just pencil whipping the counts, for whatever reason (plenty of valid reasons for it, when you ignore the binds it put us in).
    Combine that with lazy FIFO and ordering from an outside supplier that has much less incentive to say "no, I won't sell you another 500 units" (which is all they supply to that facility, unlike us), and it's much easier to see how 2mo old units could be used.
    Especially when there's nothing different about the S/C to plant personnel, whereas body surface defects are meticulously examined for. Even if they knew there was a difference, I'd bet folding money someone was like "They can just take their car to the dealer for isolated update, rest of the unit is OK".
  7. #126
    CRK
    CRK is online now
    Active Member
    Join Date
    Jan 2017
    Location
    Raleigh NC area at the "Peak of Good Living"
    Posts
    165
    Likes (Given)
    0
    Likes (Received)
    3
    I call BS (Given)
    0
    0
    I am that guy
    2010 Black Raven Sedan A6 Recaros Sunroof
    Airaid, QTP Cutouts with MME Ground n' Pound turn downs, Black Moon Splitter, ZL1 Blower Lid reinforced by ruskiyab
  8. #127
    Active Member
    Join Date
    Mar 2017
    Location
    Dallas, TX
    Posts
    76
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Sorry if this has been asked before but is it really VIN specific for the recall?? I called 2 dealerships and GM and they said my VIN was not affected but I can hear the rattle at idle and even had a buddy that has had 2 CTS-Vs tell me that my internal bearings are bad and need to be replaced. I just got the car and it has 79k miles. Want to know if I should keep fighting for it or Reid they are right about being VIN specific.
  9. #128
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    13,637
    Likes (Given)
    0
    Likes (Received)
    397
    I call BS (Given)
    0
    13
    Quote Originally Posted by Tdotwin View Post
    Should only cover 2009-2013, I don't think 2014-15 V2 are included.
    Just put a solid ISO in it.
    Replacement is overrated
    679RWHP 662RWTQ
    BMF cam
    ID850's
    IW 9.1/2.55
    Norcal ice tank
  10. #129
    Active Member
    Join Date
    Mar 2017
    Location
    Dallas, TX
    Posts
    76
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    I have a 2011 and was hoping to get a new supercharger to start modding the engine and feel at ease with the new SC in Iit. Is it EVERY 09-13 v model?
  11. #130
    Join Date
    Jul 2011
    Location
    Los Angeles
    Posts
    16,165
    Likes (Given)
    380
    Likes (Received)
    343
    I call BS (Given)
    10
    19
    If it's not making noise, don't bother with it.
    Sales@dynamicflowconcepts.net
    Dynamicflowconcepts.net
  12. #131
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    13,637
    Likes (Given)
    0
    Likes (Received)
    397
    I call BS (Given)
    0
    13
    2011 absolutely is covered unless it was already replaced once.
    679RWHP 662RWTQ
    BMF cam
    ID850's
    IW 9.1/2.55
    Norcal ice tank
  13. #132
    Active Member
    Join Date
    Mar 2017
    Location
    Dallas, TX
    Posts
    76
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Quote Originally Posted by Karch View Post
    Yes it is making a noise but they said my vin shows it's not one that needed to be replaced.
  14. #133
    Join Date
    Jul 2011
    Location
    Los Angeles
    Posts
    16,165
    Likes (Given)
    380
    Likes (Received)
    343
    I call BS (Given)
    10
    19
    Well, you can try another dealer, or kick and scream, or try an Eaton solid coupler.
    Also, a smaller pulley might actually move the noise to an rpm below your idle speed. Do you hear it if you rev the engine to 800 rpm?
  15. #134
    Active Member
    Join Date
    Mar 2017
    Location
    Dallas, TX
    Posts
    76
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Idk I'm in the car when it revs lol. I barely had the car for a few days lol. My friend was pointing it out when He was checking it out to discuss mods for it lol
  16. #135
    Active Member
    Join Date
    Nov 2013
    Location
    Hurst TX
    Posts
    983
    Likes (Given)
    0
    Likes (Received)
    8
    I call BS (Given)
    0
    0
    Are you sure it's the SC making the noise? Pull the SC drive belt and see if it goes away.
    ID850's, 2.4 upper, Track Attack HX, Varimax pump, ZL1 Lid, Texas Speed headers, Airaid with green filter, Moroso catch can, LPE tank, PLX wideband, tuned by Pat G.
  17. #136
    Active Member
    Join Date
    Mar 2017
    Location
    Dallas, TX
    Posts
    76
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    There is a noise and my buddy has had 2 of them and told me about the recall for the noise so I trusted his word on where it came from. But I will try that this weekend.
  18. #137
    Active Member
    Join Date
    Nov 2013
    Location
    Hurst TX
    Posts
    983
    Likes (Given)
    0
    Likes (Received)
    8
    I call BS (Given)
    0
    0
    Well it's not really a recall so GM will not just replace it. It has to me making a very distinct and loud noise.
  19. #138
    Active Member
    Join Date
    Nov 2015
    Location
    NNJ/NYC
    Posts
    160
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    pulling into the garage i heard some noise after i put the car into Park... sounded more like grinding, like a bearing going bad... it went away when i revved the motor... i think it might be supercharger replacement time... i'll try to call the dealer tomorrow to schedule a drop off...
    tv4184 likes this.
    Lexus driver bought a Vagon!!!
  20. #139
    Active Member
    Join Date
    Nov 2015
    Location
    NNJ/NYC
    Posts
    160
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    dropped off the car on Friday... i waited there for 2 hrs while the tech was diagnosing the car... it was hard to hear in the service entrance since it was open... the tech confirmed there was a noise but i was told he wanted to run a few more tests to isolate the noise to the S/C... he also wanted to do a cold start test... they put me in a brand new 2017 XT5 as a loaner... i'm waiting to hear back today on what the verdict is...
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
Search tags for this page
2011 cadillac cts v supercharger rattle
2013 cts-v supercharger recall
cadillac cts special coverage 14264
cadillac special coverage 14264
cadillac special coverage 14264 warranty
cadillac warranty special coverage 14264
gm 13313 special coverage adjustment
gm special coverage adjustment
gm special coverage adjustments
gm tsb 13313
lr058080
special warranty 13313
