Oil Change
Page 1 of 2 12 LastLast
Results 1 to 30 of 32
Like Tree7Likes
Thread: Oil Change
  1. #1
    Active Member
    Join Date
    Mar 2013
    Posts
    50
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    I call BS (Received)
    0
    Oil Change
    Getting ready to try and change my own oil. 70 bucks at the local oil change places is crazy to me. $30 for 7 quarts of Mobil 1 at Costco and a few bucks for oil filter, seems like doing it myself is a better idea. So can anybody give me some step by steps on how to go about this. I have never done an oil change myself except on quads and dont want to screw anything up. Is there any thing that needs to be removed to get to the oil plug and where is it located. Where is the oil filter located and are there any covers that need to be removed to get to that?
  2. #2
    still hanging around
    Join Date
    Jul 2011
    Location
    Bragg Creek, AB
    Posts
    4,222
    Likes (Given)
    15
    Likes (Received)
    97
    I call BS (Given)
    0
    4
    Oil change is easy, nothing to remove. And get the bigger filter that Tony identified in the filter sticky...PF63.
    2010 CTS V Sedan - 10.25@139.8 ...bone stock, factory freak
  3. #3
    Active Member
    Join Date
    Mar 2013
    Posts
    50
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Why bigger filter
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Active Member
    Join Date
    Mar 2013
    Posts
    50
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Do I need to jack front and rear of car up on jack stands or just front?
    Does car need to be warm or cold?
    Do I drain all the oil out of pan and then change the filter?
    Does the filter need to have oil put in it?
    Does the oil filter come off with an oil filter wrench or by a socket?
    This will be my first attemp at this that is why so many questions. Want to make sure I know what I am doing before buying all the oil and filter,.
  6. #5
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    13,639
    Likes (Given)
    0
    Likes (Received)
    397
    I call BS (Given)
    0
    13
    Quote Originally Posted by chosenone View Post
    Car warm, front end only, oil pan first, you can pre fill new filter, filter wrench helps.
    Sent from my KFTT using Tapatalk 2
    MYV likes this.
    679RWHP 662RWTQ
    BMF cam
    Ported SC/Snout/90TB
    Kooks LT w/cats stock muffs
    ID850's
    IW 9.1/2.55
    Airaid w/green filter
    Katech+W4M HX ZR1 pump
    Norcal ice tank
  7. #6
    Active Member
    Join Date
    Mar 2013
    Posts
    50
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Awesome thanks, car takes 6 quarts?
  8. #7
    Active Member
    Join Date
    Mar 2013
    Posts
    50
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Also I read the oil filter is right next to the drain plug, is this correct? WIll I know what the drain plug looks like when I see it? Do I need to buy the normal oil filter wrench or the one with the head that pivots? Is the oil filter easily accessible with an oil wrench? thanks
  9. #8
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    13,639
    Likes (Given)
    0
    Likes (Received)
    397
    I call BS (Given)
    0
    13
    Drain plug is at the rear of the oil pan, very obvious and filter is nested right next to oil pan. I use the strap style filter wrench.
    679RWHP 662RWTQ
    BMF cam
    ID850's
    IW 9.1/2.55
    Norcal ice tank
  10. #9
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    13,639
    Likes (Given)
    0
    Likes (Received)
    397
    I call BS (Given)
    0
    13
    6 quarts
    679RWHP 662RWTQ
    BMF cam
    ID850's
    IW 9.1/2.55
    Norcal ice tank
  11. #10
    Active Member
    Join Date
    Nov 2011
    Location
    Farmington Hills MI
    Posts
    952
    Likes (Given)
    37
    Likes (Received)
    24
    I call BS (Given)
    7
    0
    Jack Stands PLEASE!
    IF IT FLYS, FLOATS OR F**KS...RENT IT!
    A patient of the Dr. Phil Horsepower Hospital.
  12. #11
    Dick Pickles
    Join Date
    Nov 2011
    Location
    Kailua, HI
    Posts
    5,403
    Likes (Given)
    295
    Likes (Received)
    116
    I call BS (Given)
    32
    18
    All great advice!
    While you're down there, you might as well throw in a cam.
    Hidden Content <---LINK
    '11 CTS-V Wagon M6 Loaded, hardtop
    '02 T/A WS6 SR N/A 408 (8's)
    '69 Camaro SS
  13. #12
    Active Member
    Join Date
    Jun 2013
    Location
    Chicago Burbs
    Posts
    385
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    Take back that mobil 1, its garbage. Spend a few more bucks and get some Royal Purple or Amsoil
  14. #13
    Active Member
    Join Date
    Mar 2013
    Location
    San Antonio
    Posts
    305
    Likes (Given)
    0
    Likes (Received)
    4
    I call BS (Given)
    0
    0
    I use a couple ramps picked up at autozone for oil changes instead of jacks. I have a little incline to my driveway, so I'm able to get a little more clearance at its apex.
  15. #14
    Active Member
    Join Date
    Mar 2013
    Posts
    50
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Wont the V drag front bumper if you pull up and down ramps?
  16. #15
    Active Member
    Join Date
    Aug 2011
    Posts
    4,045
    Likes (Given)
    7
    Likes (Received)
    36
    I call BS (Given)
    0
    2
    Get a set of race ramps, I think they are 56" long or something to that effect. Work slick, expensive but get the job done!!!
  17. #16
    Active Member
    Join Date
    Mar 2013
    Location
    San Antonio
    Posts
    305
    Likes (Given)
    0
    Likes (Received)
    4
    I call BS (Given)
    0
    0
    I'll revise my comment, They worked fine on my lowered (GC) V1 and did not drag accept for that rubber. Just lowered the V2, I'll test it out and report back.
  18. #17
    Active Member
    Join Date
    Jul 2013
    Posts
    879
    Likes (Given)
    0
    Likes (Received)
    23
    I call BS (Given)
    0
    1
    Autozone ramps don't fit for the front but work at the rear. A long jack lets you raise the whole front easily though and then just slide jack stands under the lift points on either side.
  19. #18
    Active Member
    Join Date
    Feb 2013
    Posts
    8,549
    Likes (Given)
    1073
    Likes (Received)
    299
    I call BS (Given)
    18
    18
    My car is not lowered, but I have a metal "low profile" jack from sears (approx 3.5" clearance for the cup) that easily fits under the car and reaches the front cross member.
    Any jack that is <5" tall should work well.
  20. #19
    Active Member
    Join Date
    Apr 2013
    Posts
    79
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Why bigger filter
    I never saw this answered. I'm curious too.
  21. #20
    Active Member
    Join Date
    Sep 2012
    Location
    San Antonio
    Posts
    2,633
    Likes (Given)
    3
    Likes (Received)
    58
    I call BS (Given)
    0
    0
    more often than not, bigger filter = more media surface area.
  22. #21
    Active Member
    Join Date
    Feb 2013
    Location
    NH
    Posts
    1,637
    Likes (Given)
    1
    Likes (Received)
    22
    I call BS (Given)
    1
    1
    I went to the dealer because I heard the zr1 filter is the same as our v2's except for the oil capacity and so I ordered both from them but got the same pf part number filter for both vehicles so what is the vet p/n?
    Sent from my iPad using Tapatalk - now Free
    2013 OBM M6
  23. #22
    Join Date
    Jul 2011
    Location
    Bragg Creek, AB
    Posts
    4,222
    Likes (Given)
    15
    Likes (Received)
    97
    I call BS (Given)
    0
    4
    Quote Originally Posted by CJ11V View Post
    More media and more oil in the system.
  24. #23
    Active Member
    Join Date
    Apr 2013
    Posts
    79
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Quote Originally Posted by never View Post
    I understand that more media means more contaminates removed, but how does more oil help? Just seems like it might make the system work harder.
  25. #24
    Active Member
    Join Date
    Apr 2013
    Location
    Calgary AB
    Posts
    4,520
    Likes (Given)
    0
    Likes (Received)
    114
    I call BS (Given)
    0
    9
    Quote Originally Posted by Gootz View Post
    More oil means it will dilute the contaminates better. It doesnt put pressure on the system, just allows for more "fresh stuff". The same idea with having more water in your cooling system.
    Ill edit this just as a warning I dont know much about the LSA oil capacity so I dont know how much oil is safe, but I only said what I did because my work van hold 13 liters and I dont have to oil change for 16000km and had asked the same question you did at one point. That was the explanation I got.
  26. #25
    Active Member
    Join Date
    Aug 2012
    Location
    NW Peoria AZ
    Posts
    927
    Likes (Given)
    0
    Likes (Received)
    12
    I call BS (Given)
    1
    0
    Bigger filter= bigger surface area for filtration which= more flow.
    Same theory as running a bigger air filter.
    Work in progress
  27. #26
    Active Member
    Join Date
    Jul 2013
    Posts
    879
    Likes (Given)
    0
    Likes (Received)
    23
    I call BS (Given)
    0
    1
    That's assuming the limiting factor in the system is the oil filter. While that's the case for an air filter, I'm not sure that's a safe assumption for an oil filter. Your engine oil gallery is far more flow limiting than your oil filter. I'd guess the oil gallery is your bottleneck and a bigger filter does nothing for improving flow.
  28. #27
    Active Member
    Join Date
    Aug 2012
    Location
    NW Peoria AZ
    Posts
    927
    Likes (Given)
    0
    Likes (Received)
    12
    I call BS (Given)
    1
    0
    This may be true, hence oil pressure is inversely related to flow.
    I've never measured nor care to measure flow of our oil system. I was answering a simple question. A larger surface area of a filtration media or any opening allows more flow, period.
    Whether it is necessary who knows, but it definitely won't hurt.
    Work in progress
  29. #28
    Registered User
    Join Date
    Nov 2013
    Location
    Elgin, IL
    Posts
    38
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Great information, always did the oil changes on my G8 (9 quarts) and plan on doing the same with the CSTV now. Just picked one up 10 days ago. I will check the ramps out as that seems to be the best method.
    2017 Black Raven
  30. #29
    Active Member
    Join Date
    Apr 2013
    Posts
    325
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    2
    Anyone have warranty problems with the PF63 ??
  31. #30
    Active Member
    Join Date
    Apr 2014
    Location
    MD
    Posts
    76
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Quote Originally Posted by prdnme View Post
    All great advice!
    And some neon lighting..
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
Search tags for this page
best oil filter for cadillac cts-v
cadillac cts v oil change
cts-v oil filter tool
ctsv oil filter
how many quarts of oil does a cadillac cts v take
how many quarts of oil for cts v 2011
how much oil does 2011 cadillac cts take
oil capacity for ctsv
oil change
oil change cts-v
oil filter cts v
when to change oil on 2016 cts v
