Clutch options and advice
Results 1 to 17 of 17
Like Tree2Likes
  • 1 Post By Lt1z
  • 1 Post By 1madstsv
Thread: Clutch options and advice
  1. #1
    Registered User
    Join Date
    Oct 2015
    Posts
    3
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    I call BS (Received)
    0
    I have an '09 CTSV sedan with an M6 trans. The stock factory clutch gave up on me yesterday at the drag strip. The car is stock with 100,000 miles on the factory clutch. It has an afraid CAI, and a drag radial on in for drag strip only. I go to the track maybe 3 times a year, early spring or fall. I will change the upper pulley and do a tune after i figure out what clutch to use. The car 60 foots fairly hard from what I've been told and runs good for being stock within tune.
    I am looking for your guys advice and input on what clutch to re-install ?
    Also, can the stock/factory flywheel be resurfaced and reused successfully with no issues?
    Thanks for any input you guys can give me
  2. #2
    Join Date
    Jul 2011
    Posts
    10,524
    Likes (Given)
    249
    Likes (Received)
    183
    I call BS (Given)
    0
    3
    Id just replace with new factory discs, pressure plate and flywheel
  3. #3
    Active Member
    Join Date
    Aug 2016
    Location
    Orlando
    Posts
    350
    Likes (Given)
    0
    Likes (Received)
    4
    I call BS (Given)
    0
    0
    I'm of the opposite thinking. If you're going to do more mods then might as well only do the clutch once because its not an incredibly fun job to do.
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Join Date
    Jul 2011
    Posts
    10,524
    Likes (Given)
    249
    Likes (Received)
    183
    I call BS (Given)
    0
    3
    Quote Originally Posted by TheTinMan View Post
    No need if he's just CAI only. The aftermarket clutches for this application are pretty expensive for mild mods
  6. #5
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    13,637
    Likes (Given)
    0
    Likes (Received)
    397
    I call BS (Given)
    0
    13
    The driveability of the stock clutch is still hard to beat. So nice.
    Still waiting for my stocker to fail
    679RWHP 662RWTQ
    BMF cam
    Ported SC/Snout/90TB
    Kooks LT w/cats stock muffs
    ID850's
    IW 9.1/2.55
    Airaid w/green filter
    Katech+W4M HX ZR1 pump
    Norcal ice tank
  7. #6
    Active Member
    Join Date
    Aug 2016
    Location
    Orlando
    Posts
    350
    Likes (Given)
    0
    Likes (Received)
    4
    I call BS (Given)
    0
    0
    Quote Originally Posted by Lt1z View Post
    But he also said he was planning an upper pulley as well which typically leads to other mods too. My stock clutch failed at 580whp. Went to a triple disk and I have no regrets. Money well spent to not have to pull the trans out later.
  8. #7
    Active Member
    Join Date
    Aug 2011
    Location
    Germany
    Posts
    1,956
    Likes (Given)
    0
    Likes (Received)
    28
    I call BS (Given)
    0
    1
    At that power level, I'd stay stock and they're relatively cheap. He won't need a triple unless around 1000 ish. Factory has the best drivability.
    Manny
    2009 Black Raven CTS-V 6MT
    416ci LSA
    Stock Ported Heads
    Twin Precision 6266s
    FORE Triple TI267s
    RPS Triple Carbon
    1155rwhp/1122rwtq @20psi (E60)
    Hidden Content
  9. #8
    Active Member
    Join Date
    Mar 2015
    Posts
    1,939
    Likes (Given)
    0
    Likes (Received)
    55
    I call BS (Given)
    0
    0
    I did a twin and I'm now at 758hp.
    Stock drove best but no way would it hold this power with bite.
    2012 CTS-V Coupe 6MT - 4.5"/102 combo, fully ported blower, TEA Stg2 LSA heads, LT1Z Stg 2.5 cam, SW 2" Catless, 2.5/9.1 pullies, -10 ZL1 lid, ID850's, TA+low mount, Varimax, Norcal, etc. Tuned by Mike @ New Era. Labor by New Era Performance. 720 hp & 659tq
    APRIL 2017: DSX Aux Pump, DSX Flex Sensor, ID1000's & Corsa Touring. Installed @ Weapon X Motorsports. Tuned by Jeremy@WXM - 708whp on pump - 758 on E58
  10. #9
    Active Member
    Join Date
    May 2013
    Location
    York/Baltimore
    Posts
    501
    Likes (Given)
    0
    Likes (Received)
    14
    I call BS (Given)
    0
    0
    My monster triple drives as good if not better than stock. Over 5000 miles on it now no issues. 820 hp 940 Tq
    TheTinMan likes this.
  11. #10
    Registered User
    Join Date
    Apr 2017
    Posts
    30
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Quote Originally Posted by 1madstsv View Post
    Reviving this thread. I see that you have a Monster clutch, how do you like it so far? would you recommend a monster clutch? I am in the market for a clutch and was looking at the Monster LT1-SC Twin Disc Clutch and Flywheel.
  12. #11
    Active Member
    Join Date
    May 2013
    Location
    York/Baltimore
    Posts
    501
    Likes (Given)
    0
    Likes (Received)
    14
    I call BS (Given)
    0
    0
    So far so good and I'm very hard on it. Mine is the tripple so I can't speak for the twin. But it should be very similar.
  13. #12
    Active Member
    Join Date
    Aug 2016
    Location
    Orlando
    Posts
    350
    Likes (Given)
    0
    Likes (Received)
    4
    I call BS (Given)
    0
    0
    I have the Monster LT1-S triple as well. Drives just as well if not better than stock and takes a beating.
    '09 Thunder Grey M6
    New Era 4.5 w/ Green Filter, BBK 102mm TB ported by me, Jokerz Chaos Ported Blower/Snout, 9.55/2.45 pulley combo, LT1Z stage 3 cam, XtremeCFM heads, Johnson Lifters, FID1300s, AEM in tank pumps, DSX Aux Pump, Flex Fuel, TSP 2" Headers, MBRP 26" Resonators, ZL1 NPP Mufflers, Monster LT1-S Triple Disk, Core Shifter, Russell Justus billet lower shift box, ZL1 Lid, Reprogrammed EMP Hx Pump, Vadder Destroyer Hx, D3PE "Prospeed" Reservoir
    Current best 1/4 - 2nd pass on this setup, kicked off the track, on 20's and street tires, 10.97 @ 135.4
  14. #13
    Registered User
    Join Date
    Apr 2017
    Posts
    30
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Thanks fellas. When you guys purchased the triple did it come with new slave and flywheel as well?
  15. #14
    Active Member
    Join Date
    Aug 2016
    Location
    Orlando
    Posts
    350
    Likes (Given)
    0
    Likes (Received)
    4
    I call BS (Given)
    0
    0
    Flywheel yes, slave no.
    '09 Thunder Grey M6
  16. #15
    Registered User
    Join Date
    Apr 2017
    Posts
    30
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    I assume you used a factory slave when replacing
  17. #16
    Active Member
    Join Date
    Aug 2016
    Location
    Orlando
    Posts
    350
    Likes (Given)
    0
    Likes (Received)
    4
    I call BS (Given)
    0
    0
    Quote Originally Posted by LSACOBRA View Post
    Of course.
    '09 Thunder Grey M6
  18. #17
    Registered User
    Join Date
    Jan 2015
    Location
    San Antonio, TX
    Posts
    32
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    I figured this is a good place to ask. As far as I can tell, the RAM flywheels are meant to work with an OEM disk/pressure, plate, right? https://www.texas-speed.com/p-4125-r...sx-8-bolt.aspx
    I hope to not need to muck with my transmission or clutch for a really long time, but if I ever do, it would be nice to save a little weight and $200 (OEM flywheel is $550).
    2009 WDT 6MT CTS-V - SW headers, Corsa axleback, Airaid intake, LS7 throttle body, Moroso catch can, DMS reinforced brick, Creative Steel shifter, Voodoochikin/Kerbid driveshaft carrier
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
