cam and pulley set up.
Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By fubar569
  • 1 Post By HunterC
Thread: cam and pulley set up.
  1. #1
    Active Member
    Join Date
    Nov 2014
    Location
    NJ
    Posts
    175
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    I call BS (Received)
    1
    I currently have a 2.4 upper and plan to do a cam and lower pulley.
    From what I gathered on the forum I need a 8.6 lower as a 9.1 will be to much unless I run E85 all the time which I will not be.
    I DD the car and will only be filling up E85 on the weekends or nights out in Mexico.
    Is this correct?
    Also is there an off the shelf cam that works? I don't want the LS9 cam because if I am going through the hassle of cam install I expect to hear it.
    My expectations of the cam in order are:
    1. sound - should sound like a 108 lsa lol I want it to sound like a BBC Cam
    2. drive-ability
    3. power
    and last does anyone have sound clips of any cam they are going to suggest.
    My 02 TA has a rear mount turbo that Tick spec'ed out and it made huge power for the boost I was running but it sounded almost stock.
    Current mods are:
    2.4 upper with 100mm idler
    ported snout
    stock ported throttle body
    4.5" dynospeed intake
    flex fuel kit
    BB catback
    ZL1 lid with -10 an's
    and
    83lb injectors which are maxed out. I'll be upgrading to 1000-1300's during this build.
    Currently the car made 557/563 on 93 and 615/613 on e85
  2. #2
    Active Member
    Join Date
    Oct 2012
    Posts
    7,113
    Likes (Given)
    2
    Likes (Received)
    152
    I call BS (Given)
    0
    11
    Id say 2.4/8.6 and a stg 3 cam fr om btr or lt1z if you wanna hear it.
    Sent from my SM-G920V using Tapatalk
    2013 CTSV Wagon A6
    10.19@132mph 1.48 60 foot
    stg 2 lt1z cam, 10.5 lower, air raid intake, b&b test pipes, ls7 tb on 93 octane 627rwhp
    New setup:
    stg 2.5 lt1z cam 10.5 lower air raid TSP Longtubes jokerz port 660rwhp
    no 1/4 mile yet
  3. #3
    jrV
    jrV is offline
    Active Member
    Join Date
    Feb 2015
    Location
    Wichita, KS
    Posts
    825
    Likes (Given)
    19
    Likes (Received)
    23
    I call BS (Given)
    0
    0
    Subd for knowledge. In same boat, though I'm in it for power, drivability, then sound. I plan on doing heads and headers as well, though.
    Are you m6 or a6? That'll will have some play on drivability and cam selection.
    - 2011 TGC Sedan | A6 | Recaro's | Ultraview | Suede
    - 2015 Suzuki GSXR 1000
    - Current V Mods: AIRAID CAI w/green filter | Mamo Ported TB | Elite Engineering Catch Can | DSX Flex Fuel Kit/Filter/Aux Fuel Pump Kit | ZL1 Lid | Fluidyne T-Rex HX | Varimax HX pump | Solid iso | Kook's Headers w/green cats | 2.4" upper | 100mm idler | ID1300's | TR7's | LTZ1 stg 2.5 cam | Pat G Tuned
    - WTB: Ported TFS Heads | Ported blower/snout | Weld RT-S S71's and DR's
    - Cosmetic/misc: Velgen VMB5 - Nitto NT555 G2 | Eibach Pro Kit | HID Fogs | VLED DRL's | 20% tint | Aeroforce Interceptor w/wideband | Escort 9500ix w/Blendmount | STS paddle shifters | WeaponX CF/FG power hood | WeaponX CF Fog Bezels
  4. #4
    Active Member
    Join Date
    Mar 2015
    Posts
    1,728
    Likes (Given)
    0
    Likes (Received)
    47
    I call BS (Given)
    0
    0
    You need more fuel pump to run more E.
    You can run a 2.4/9.1 with aggressive cooling when not on E...although the preferred ratios for safety are 2.4/8.6 or 2.5/9.1.
    I will be installing a LT1Z stg 2.5 on my 6spd car with cnc'd heads and a 2.5/9.1 combo. Seems to be the sweet spot for a good reliable package...
    2012 CTS-V Coupe 6MT - Metco 2.5 Pulley, Solid Iso, Carbon Fiber Intake pipe, Modded Airbox, K&N, 63lb Injectors. Tuned by Mike @ New Era. Labor by New Era Performance.
    68* - 22% humidity - SAE .99 - 578 hp & 577 tq - Track Times TBD
  5. #5
    Active Member
    Join Date
    Nov 2014
    Location
    NJ
    Posts
    175
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    1
    I only have two stations in my area and even those are 30min each way for me. So a pure E car isn't an option.
    If I go crazy with heads and engine work I'll modify the fuel system. At my power level the stock system is still fine.
    I am A6.
    I'll check out stg 3 cam from btr or lt1z
    Thanks
  6. #6
    Active Member
    Join Date
    Apr 2014
    Location
    Michigan
    Posts
    1,171
    Likes (Given)
    67
    Likes (Received)
    27
    I call BS (Given)
    2
    2
    Stage 2.5 from Matt (LT1Z) along with 2.5/9.1 pullies. PM me your email address and I'll send you a clip
    Sent from my iPad using Tapatalk HD
    Hidden Content
    2011 A6 Sedan Black Diamond Edition w/ Recaros and lowered w Eibach
    4.5" CAI, NW102 TB, ported Snout, ported SC, 2.5/9.1 pullies, ZL1 lid, ported TF heads,
    ID850 injectors, SW headers w Xpipe, LTZ1 stage 2.5 cam, Track Attack HX, Norcal Icebox,
    Forged Lower built by Baker Engineering, Tuned by Dr Phil
    [SIGPIC]
  7. #7
    Active Member
    Join Date
    Mar 2015
    Posts
    1,728
    Likes (Given)
    0
    Likes (Received)
    47
    I call BS (Given)
    0
    0
    My point was with a more aggressive setup...i.e. cam and lower...you will not have enough pump to even support your current level of ethanol...if you are maxed at 616whp on E right now...a larger injector isn't gonna do you a lot of favors...a typical 85lb is plenty if you have the fuel flow to support It.
    Jchastain likes this.
  8. #8
    Active Member
    Join Date
    Jun 2015
    Location
    Jacksonville, NC
    Posts
    76
    Likes (Given)
    0
    Likes (Received)
    8
    I call BS (Given)
    0
    0
    Subscribing for knowledge. Looking for a similar build, though without the ethanol.
    2012 Cadillac CTS-V Wagon | A6 | Black Raven | Air Raid | Corsa | RED springs - 508 RWHP, 493 Ft-lbs @ 97 degrees
    1998 Land Rover Discovery SE7 | A5 | Tactical 4x4 front | OME HD 2" lift | Baja Rack EXP | Talon 9500
    Custom rocker blades - contact Sal, he's the man!
    Hidden Content
  9. #9
    Active Member
    Join Date
    Jan 2014
    Location
    Brooksville FL
    Posts
    66
    Likes (Given)
    0
    Likes (Received)
    7
    I call BS (Given)
    0
    0
    Quote Originally Posted by Raist103 View Post
    Check out this thread.. GP Tuning LSA Cam Descriptions
    keoni004 likes this.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
