What's a realistic gain from a cam swap?
Results 1 to 26 of 26
  1. #1
    Active Member
    Join Date
    Apr 2013
    Location
    West Palm Beach, FL
    Posts
    457
    Likes (Given)
    0
    Likes (Received)
    12
    I call BS (Given)
    0
    I call BS (Received)
    0
    Take a stock car, toss a ls9/zr1 cam in it, what would be the gains?
    Stock for stock with a cam. I know a tune is required so taking the tune out of the equation what should you expect from the cam itself.
  2. #2
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    13,048
    Likes (Given)
    0
    Likes (Received)
    383
    I call BS (Given)
    0
    13
    30 rwhp
    Sent from my KFTT using Tapatalk 2
    679RWHP 662RWTQ
    BMF cam
    Ported SC/Snout/90TB
    Kooks LT w/cats stock muffs
    ID850's
    IW 9.1/2.55
    Airaid w/green filter
    Katech+W4M HX ZR1 pump
    Norcal ice tank
  3. #3
    Active Member
    Join Date
    Aug 2013
    Location
    San Antonio TX
    Posts
    783
    Likes (Given)
    4
    Likes (Received)
    16
    I call BS (Given)
    0
    1
    Thats a good jump from a mild cam
    Sent from my SCH-I605 using Tapatalk 2
    2009 CTSV A6
    Mod list includes:
    ID850
    Ported Snout
    Ported LS7 Throttle Body
    Air raid
    Fluidyne Front Mount HX
    Norcal Ice Box
    LT1Z 2.5 Cam/Springs/Push rods
    2.5 Upper/9.1 Lower 15 lbs Boost
    Kook long tubes mid and cat back
    External mods:
    Weapon X Carbon Hood
    Carbon Vents
    Carbon Side Blades
    661 HP/639 TQ
    G-Force Tuned
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Join Date
    Jul 2011
    Location
    Los Angeles
    Posts
    14,978
    Likes (Given)
    355
    Likes (Received)
    314
    I call BS (Given)
    10
    19
    It's been done many times, and 30 rwhp is a pretty good number.
    Just shows how under-cammed these are.
  6. #5
    Join Date
    Jul 2011
    Posts
    9,867
    Likes (Given)
    221
    Likes (Received)
    176
    I call BS (Given)
    0
    3
    Quote Originally Posted by Karch View Post
    They left a lot of the table with the LSA trying to keep it Caddy tame. The good news is that large gains can be had from a simple cam swap.
    30ish from an ls9
    50ish from a stage 1 type cam
    and it goes up from there depending on supporting mods.
  7. #6
    Active Member
    Join Date
    Aug 2013
    Location
    San Antonio TX
    Posts
    783
    Likes (Given)
    4
    Likes (Received)
    16
    I call BS (Given)
    0
    1
    No kidding cant wait to put in my lt1z 2.5 cam
    2009 CTSV A6
    Mod list includes:
    ID850
    Ported Snout
    Air raid
    Norcal Ice Box
    External mods:
    Carbon Vents
    Carbon Side Blades
    661 HP/639 TQ
    G-Force Tuned
  8. #7
    Join Date
    Jul 2011
    Posts
    9,867
    Likes (Given)
    221
    Likes (Received)
    176
    I call BS (Given)
    0
    3
    Quote Originally Posted by CCTSV View Post
    Tracking shows that it will be delivered tomorrow.
  9. #8
    Join Date
    Jul 2011
    Posts
    9,867
    Likes (Given)
    221
    Likes (Received)
    176
    I call BS (Given)
    0
    3
    Quote Originally Posted by Boosted2000si View Post
    The is required for more then just the spark and fuel adjustments. The LS9 has a higher power curve then the LSA so at the very least the rev limiter and shift points would need to be changed to realize the gain.
  10. #9
    Active Member
    Join Date
    Mar 2013
    Location
    SW Florida
    Posts
    122
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    Dang, 30rwhp will feel nice. So what's the typical tuner upping the shift points to with the ZR1 cam?
    I also just bought a ZL1 lid... So I might be looking at a total gain of 50rwhp. I am stoked
    2010 Black CTS-V
    10.6 @ 130
  11. #10
    Join Date
    Jul 2011
    Posts
    9,867
    Likes (Given)
    221
    Likes (Received)
    176
    I call BS (Given)
    0
    3
    Quote Originally Posted by venomized03 View Post
    6500
  12. #11
    Autism Speaks. Listen
    Join Date
    Oct 2012
    Location
    Sacramento, Ca
    Posts
    1,176
    Likes (Given)
    26
    Likes (Received)
    30
    I call BS (Given)
    2
    0
    Quote Originally Posted by Lt1z View Post
    30ish from an ls9
    would hp gains still be this significant without headers?
    2014 Esky Blk/Blk Loaded
    Stock
    2011 CtsV Blk/Blk Loaded
    Under Construction...
    2011 S4 Quartz/Blk Loaded
    034 Stg3 11.55@119mph 91/E85 +1360Da
    2011 RxpX Turbo Blk/Fire
    E85 Monster Hidden Content
  13. #12
    Join Date
    Jul 2011
    Location
    Los Angeles
    Posts
    14,978
    Likes (Given)
    355
    Likes (Received)
    314
    I call BS (Given)
    10
    19
    Quote Originally Posted by gOt BoOsT View Post
    With the LS9, probably. With larger cams you get decreasing returns through manifolds.
  14. #13
    Active Member
    Join Date
    Aug 2011
    Posts
    1,449
    Likes (Given)
    1
    Likes (Received)
    53
    I call BS (Given)
    0
    2
    Every time we do a camshaft we add a 9.1 lower. Gains of usually 100-130 RWHP.
    2nd FASTEST 1/4 MILE CTS-V 9.44 @ 149 MPH
    HOME OF THE FASTEST 1 MILE CTS-V 200.9 MPH
    HOME OF THE FASTEST 1/4 MILE SUPERCHARGED C6 Corvette 8.45 @ 163 MPH
    HOME OF THE FASTEST 1/4 MILE C6 M6(non Z06/ZR1) 9.6 @ 148 MPH
    G-FORCE Motorsports
    1941 CR 129 Pearland TX 77581
    281-993-5451 PH 281-993-5421 FAX
    Hidden Content
    Hidden Content
    PCM Tuner LSX and SCT <-> How Much Force Can You Take??
    2013 FORD RAPTA
    2010 TTT5 & OTTA Extreme Street Champions
  15. #14
    8s are the new 9s
    Join Date
    Jun 2012
    Location
    Germantown, TN
    Posts
    4,091
    Likes (Given)
    208
    Likes (Received)
    129
    I call BS (Given)
    4
    4
    Quote Originally Posted by Mike TexaSS View Post
    Definitely pulley it if your installing the cam. They go together like peanut butter and jelly.
    DynoSpeed Racing Built and Tuned
    Mods: DynoSpeed 4.5 inch intake (Hidden Content ), ZL1 lid, meth, WeaponX Hood, DSteck flex fuel with squash system, Guard dog trunk tank, 15s
    Soon to be updated...
  16. #15
    Active Member
    Join Date
    Feb 2013
    Location
    Miami, FL
    Posts
    749
    Likes (Given)
    5
    Likes (Received)
    14
    I call BS (Given)
    0
    0
    And this is the reason I ordered my entire pulley system with my BTR stage 3 cam.
    9.1 lower and 2.5 upper with all the supporting pulleys also from Metco Motorsports.
    Can't wait
    2010 Envy Green Widebody Sedan A6
    Performance
    D3 Air Intake | MSD Wires | TR7Ix Spark Plugs | 36" Double Wide HX | White DP Hoses| EBC Dimple and Slotted Rotors
    Look Pretty Parts
    AirREX Race Air Suspension | Forged Vossen Precision Series Split 10 Twist: Front: 20x10.5 w/ T1R 305/25/20, Rear: 20x12 w/ T1R 345/25/20 | D3 Roof Spoiler | Specter Werkes Trunk Spoiler | Power Hood | White LED conversation interior and license plate | V1 Radar Hidden Content
    Mod Pile
    | BTR Stage III Cam | BTR .660" Lift Platinum Dual Spring Kit | BTR Chromoly Push-rods | Metco Motorsports Full Pulley Kit; 2.5 Upper, 9.1 Lower, Isolator, S/C Drive Tensioner Pulley, Accessory Bullet Tensioner Pulley, 50mm and 100mm Idler Pulley | Meisterschaft Performance Exhaust W/ AR Pipe, X-Pipe, and EV Wireless Control | ZEX EFI Wet Nitrous System | ZEX -4AN Liquid Filled Gauges Kit | ZEX Wire-in Nitrous Bottle Heaters | ZEX -4AN Dual Outlet Purge Kit | Aerospace Dual Nitrous Bottle Bracket | ARH 2" Headers with 3" Piping |
    Waiting Shipment
    ID1000 | KW Mag. Delete modules
    Hidden Content | Hidden Content | Hidden Content | Hidden Content | Hidden Content | Hidden Content | Hidden Content
  17. #16
    Join Date
    Aug 2011
    Posts
    1,496
    Likes (Given)
    40
    Likes (Received)
    25
    I call BS (Given)
    0
    0
    In my case (09 6M), LS9 with 2.4 upper only on ported snout with ported LS7 TB, 85lb injectors, plug swap, hardened pushrods, PAC1518 springs and rocker swap on stock manifolds and netted 45whp and 40 torque on 6350 RPM limit, zero KR. Added ZL1 and picked up additional 15whp and 20 torque. Idle barely discernible from OEM, which is what I wanted.
  18. #17
    Active Member
    Join Date
    Aug 2011
    Posts
    1,449
    Likes (Given)
    1
    Likes (Received)
    53
    I call BS (Given)
    0
    2
    I had the LS9 camshaft in my personal V. I loved it!
    G-FORCE Motorsports
    Hidden Content
    Hidden Content
    2013 FORD RAPTA
  19. #18
    Active Member
    Join Date
    Mar 2013
    Location
    Philly/Morristown, NJ
    Posts
    781
    Likes (Given)
    7
    Likes (Received)
    6
    I call BS (Given)
    0
    0
    Quote Originally Posted by jb_bgg View Post
    You and I have basically the same set up sans the LS9 Cam and ZL1 intake manifold. Like you, I desire a very smooth stock like idle with zero drivability issues even if I sacrificing 15 + RWHP/TQ.
    My question:
    Is it a worth wile investment getting the LS9 cam, with ZL1 lid, coupled with long tube headers to stock cat back?
    Also, am I asking for problems if I go with a lower like the 8.6 or 9.1? I am content for now since my car was just modded and I still getting used to the power increase over stock, but I know I will probably yearn for more in the future. My concern is all of the engine issues threads that have been popping up lately that seem to always have both upper and lower pulley combos.
  20. #19
    Active Member
    Join Date
    Aug 2013
    Location
    San Antonio TX
    Posts
    783
    Likes (Given)
    4
    Likes (Received)
    16
    I call BS (Given)
    0
    1
    Usually there is more to it. No way its going to be bullet proof with a stock short block. I wouldn't be concerned if I were you just get a good safe tune on it and respect the car and it should last you.
    2009 CTSV A6
    Mod list includes:
    ID850
    Ported Snout
    Air raid
    Norcal Ice Box
    External mods:
    Carbon Vents
    Carbon Side Blades
    661 HP/639 TQ
    G-Force Tuned
  21. #20
    Active Member
    Join Date
    Jan 2013
    Location
    SATX
    Posts
    605
    Likes (Given)
    0
    Likes (Received)
    8
    I call BS (Given)
    0
    1
    Quote Originally Posted by Hotsoss View Post
    My question:
    My opinion....If your going to do long tubes you might as well do a custom cam vs the LS9.
    2012 - Black Diamond Coupe: "Oh its stock...."
  22. #21
    Active Member
    Join Date
    Aug 2013
    Location
    San Antonio TX
    Posts
    783
    Likes (Given)
    4
    Likes (Received)
    16
    I call BS (Given)
    0
    1
    What he said ^^^^
    2009 CTSV A6
    Mod list includes:
    ID850
    Ported Snout
    Air raid
    Norcal Ice Box
    External mods:
    Carbon Vents
    Carbon Side Blades
    661 HP/639 TQ
    G-Force Tuned
  23. #22
    Active Member
    Join Date
    Mar 2013
    Location
    Posts
    781
    Likes (Given)
    7
    Likes (Received)
    6
    I call BS (Given)
    0
    0
    Very true.
  24. #23
    Active Member
    Join Date
    Mar 2013
    Location
    SW Florida
    Posts
    122
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    Question about this statement. So with a ZR1 cam swap, you recommend going with a lower pulley, for more boost? What if my car does NOT have the ported blower/snout/TB yet? I definitely plan on doing the ported stuff in the near future though. Would that be too much boost, in the meantime?
    My current mods are.. 2.5 upper, Airaid intake, 160 thermostat, Alky control single nozzle kit, Cat delete and magnaflows.
    Awaiting install, is a ZR1/LS9 cam and supporting stuff, and my new ZL1 lid came in today
    I might go ahead and do the lower if you guys think it would be OK!
    THANKS JASON
    2010 Black CTS-V
    10.6 @ 130
  25. #24
    Active Member
    Join Date
    Aug 2013
    Location
    San Antonio TX
    Posts
    783
    Likes (Given)
    4
    Likes (Received)
    16
    I call BS (Given)
    0
    1
    I would do the lower while your there.
    2009 CTSV A6
    Mod list includes:
    ID850
    Ported Snout
    Air raid
    Norcal Ice Box
    External mods:
    Carbon Vents
    Carbon Side Blades
    661 HP/639 TQ
    G-Force Tuned
  26. #25
    Active Member
    Join Date
    Mar 2013
    Location
    SW Florida
    Posts
    122
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    Even without the ported stuff? What size lower and how much boost does it add?
    2010 Black CTS-V
    10.6 @ 130
  27. #26
    Join Date
    Aug 2011
    Posts
    1,496
    Likes (Given)
    40
    Likes (Received)
    25
    I call BS (Given)
    0
    0
    In addition to DD I road course mine so I want durability over 20-25 minutes sessions of constant WOT blasts and hard braking vs. 1/4 mile blasts or occasional spirited street driving. More boost = more heat/higher IAT2's so there was a limit on how high I wanted to go. I looked at it this way; 2.5 and 9.1 lower averages around 15.5lbs boost. 2.4 only (with 100mm idler) is 15lbs. I used the $$$ I would have spent on a balancer/lower pulley and put that towards an AlkyControl meth kit pre-boost. Gave me the intake charge cooling for extended track use and the ability to safely bump the timing a bit and increase HP that way without the extra heat from more boost or KR/detonation coming into play. I went LS9 because I didn't want to mess with the heads and abuse or listen to the valve train with a more aggressive cam. Once I do the exhaust I'll pick up at least another 30WHP or perhaps a little more, and that is plenty for my use.
    If I had a do-over I would stop once all the brake and cooling mods were done (CAI, HX and pump, diff cooler, maybe alkycontrol) and put all the money I spent on power mods into the suspension. On the track THAT is where these big girls need the most help and investment; IMO OEM power is more than adequate for 98% of the owners like me tracking these cars. Anyone can drive fast going straight...
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
Search tags for this page
09 cadillac cts v supporting mods for cam
09 ctsv cam supporting mods
2009 ctsv cam on stock manifold
2013 zl1 camm swap
cam swap 2013 cts v
cammed cts-v with stock manifolds
cts v highest hp without a cam
cts-v performance gain with ls9 cam
ctsv cam requirements
how many horsepower from cam swap cts v
hp gain from ls9 cam swap
zl1 cam gains
