3-4 Shift Flares at WOT Need Help!
Results 1 to 8 of 8
Like Tree2Likes
  • 2 Post By Lt1z
Thread: 3-4 Shift Flares at WOT Need Help!
  1. #1
    Active Member
    Join Date
    Aug 2013
    Posts
    77
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    I call BS (Received)
    0
    My 3-4 shift flares at WOT. Every other gear shifts firm and crisp. The 3-4 flares in wot in touring and sport mode. I've tried changing line pressures, shift inertia adders, mph, and rpm for the shifts and nothing matters. Part throttle 3-4 shifts crisp and firm.
    Does this sound like an issue in the transmission itself vs tuning? If so, what upgraded/replacement parts can I buy to fix the issue?
    Also, I vaguely remember hearing about a transmission overfill procedure. Would this procedure help my situation? If so, what is the procedure?
    Thanks for any help!
  2. #2
    I'm Your Pusher
    Join Date
    Jul 2011
    Location
    Cin City
    Posts
    11,140
    Likes (Given)
    396
    Likes (Received)
    158
    I call BS (Given)
    1
    2
    You can try it but most likely the clutch pack is toast. That's the most common one on the 6Ls
  3. #3
    Active Member
    Join Date
    Jul 2012
    Posts
    586
    Likes (Given)
    0
    Likes (Received)
    13
    I call BS (Given)
    0
    0
    I have the same issue right now. Short of buying a completely new transmission, how can this be fixed? Are there parts that can be bought to rebuild the transmission?
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Active Member
    Join Date
    Aug 2013
    Posts
    77
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    Quote Originally Posted by acblack View Post
    I'd like to know that too.
    I have noticed that sometimes at part throttle in normal mode it flares as well. When I switch to sport mode the part throttle flare goes away. The part throttle in normal is very random and doesn't happen very often.
  6. #5
    Active Member
    Join Date
    Aug 2013
    Posts
    77
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    Got my flare fixed finally. Tweaked a few things in the tune, increased the oncoming pressure presets, adjusted the QE table, and adjusted both airmass a tables. Then did a reset and a quick relearn. She shifts perfectly now.
  7. #6
    Registered User
    Join Date
    Oct 2015
    Posts
    42
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Rick Crawford did wonders for my buddies twin turbo V Wagon (Greg) because he had some shifting issues before he had it retuned
  8. #7
    Join Date
    Jul 2011
    Posts
    10,528
    Likes (Given)
    249
    Likes (Received)
    183
    I call BS (Given)
    0
    3
    What I'm wondering is how you got a V1 T-56 to flare at all.
  9. #8
    Active Member
    Join Date
    Oct 2015
    Location
    Saxonburg, PA
    Posts
    50
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Quote Originally Posted by Lt1z View Post
    This^ lol
    2010 Thunder Grey V
    Airraid - Stainless works headers - Ported LS7 TB/Snout/blower - 2.31 Upper - ID1000s - Varimax - Norcal Ice Box - Tuned by Domin8 tuning - 609RWHP/629ftlbs on 93 IG: Grannatl86
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
