M6 non-DR times
Results 1 to 16 of 16
Thread: M6 non-DR times
  1. #1
    Active Member
    Join Date
    Sep 2015
    Location
    NC
    Posts
    54
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    I call BS (Received)
    0
    M6 non-DR times
    Hey guys, point me in the right direction if this has been a covered topic. But I was trying to get an idea of what the m6 guys are typically running with the basic bolt-ons (intake, pulley, injectors) on street tires. I checked the 1/4 mile times and there is only one car for reference.
    I get that you need DR's to take full advantage of the power, but I don't think I will ever make the switch based on how I use/enjoy my car. I do see myself making impromptu trips to the strip to meet/run with friends and family as I have done with past cars, and I would like it if the car could pull some mid-11s once I install the 2.55, intake, and injectors.
    Can anyone share their m6 on street tire experience?
  2. #2
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    13,229
    Likes (Given)
    0
    Likes (Received)
    385
    I call BS (Given)
    0
    13
    6M stock is a handful on street tires at the strip, add mods and it gets way worse.
    Just when you think DR's are the answer, a modded 6M down the strip takes driver skill and GOOD track prep through 1/2 track.
    Now, DR's on the street is awesome, way easier to hook than at a track with bad prep.
    Just saying be prepared to be humbled unless you are an awesome driver already.
    I know trainman on here ran really well with minimal mods on a 6M.
    679RWHP 662RWTQ
    BMF cam
    Ported SC/Snout/90TB
    Kooks LT w/cats stock muffs
    ID850's
    IW 9.1/2.55
    Airaid w/green filter
    Katech+W4M HX ZR1 pump
    Norcal ice tank
  3. #3
    Active Member
    Join Date
    Jun 2012
    Location
    Chelsea,MI
    Posts
    476
    Likes (Given)
    0
    Likes (Received)
    5
    I call BS (Given)
    0
    0
    Stock tune Airaid M6 street tires 2.0 60' 12.35@118
    Stock tune Airaid M6 Drag Radilas 1.76 60' 11.79@118
    Wade
    2010 Sedan Thunder Gray ChromaFlair 6 speed Manual...AirRaid CAI.
    11.79@118 Milan Dragway Michigan
    166.65 MPH Michigan Mile July 2013
    146 MPH 1/2 Mile Battle Creek Speed Fest 2015
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Active Member
    Join Date
    Sep 2015
    Location
    NC
    Posts
    54
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Yeah, my 400hp c3 was scary on 15" street tires at the track, so I would imagine it is a handful with more weight and more power. My TT stealth was AWD so 1.7 60's were pretty easy haha.
  6. #5
    Active Member
    Join Date
    Dec 2016
    Location
    Rancho Murieta, CA
    Posts
    341
    Likes (Given)
    0
    Likes (Received)
    4
    I call BS (Given)
    0
    0
    I recognize that a full tank adds unwanted weight, however, it does help put the power down.
    2009 Thunder Gray Sedan: M6, Recaros, UltraView
    - VS Forged VS-01's: 20x9.5, 20x11
    - Nitto NT555 G2's: 265/35r20, 305/30r20
    - Magnaflow mufflers
    - Airaid intake
    Hidden Content
  7. #6
    Active Member
    Join Date
    Sep 2015
    Location
    NC
    Posts
    54
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Quote Originally Posted by iceman302 View Post
    You know what, I have had my trunk loaded down with about 150lbs of gear (for National Guard drill), and it made a major impact on tirespin in 1st and 2nd gear. It's crazy how much impact that little bit of weight over the rear-end makes.
  8. #7
    Active Member
    Join Date
    Dec 2016
    Location
    Rancho Murieta, CA
    Posts
    341
    Likes (Given)
    0
    Likes (Received)
    4
    I call BS (Given)
    0
    0
    Quote Originally Posted by S7INGR4Y View Post
    And comparing weight for a full tank versus 1/3, you've got roughly 75 pounds more weight over the rear tires.
    - Airaid intake
    Hidden Content
  9. #8
    Active Member
    Join Date
    Dec 2015
    Posts
    94
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    I would get the 2.4 upper pulley since you're getting injectors unless you're worried about other things such as heat and primary cats.
  10. #9
    Active Member
    Join Date
    Sep 2015
    Location
    NC
    Posts
    54
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Quote Originally Posted by 09TXCTS-V View Post
    I already bought a whole snout with a 2.55" pulley. I'm thinking if I need any more power beyond that, intake, inj/tune, I can run e30-40 and get a boost in power without the extra heat.
  11. #10
    Registered User
    Join Date
    Feb 2013
    Location
    Chicago
    Posts
    32
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Went 12.6@115 bone stock on two different occasions after owning the car for only around a month, found 60 footing the car halfway decently on street tires is pretty much impossible.
    I'll have an airaid, SW catback, and some MT DRs in the spring, hoping for a bottom 12.
  12. #11
    Active Member
    Join Date
    Dec 2014
    Location
    Michigan
    Posts
    64
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    I went 11.9 @ 125ish I think with a 2.5 upper and cooling mods with street tires. More power and drag radials 10.5@137
    2010 CTS V 6M, Recaros 2.5/9.1, zl1 lid, headers, cam, Track Attack HX, Varimax pump, V2V lip, Airaid, Ported TB, Injectors, Eibach springs, drag radials, Flex fuel, Centerforce, 10.5 @ 136.5
    2004 Silverado SS Forged 370, Billet S480, 4l80e, E85 10.18@ 134 (slipping trans)
    2008 BMW 335 XI FBO, ER Intercooler, JB4
  13. #12
    Active Member
    Join Date
    Jul 2014
    Location
    Ashburn, VA
    Posts
    139
    Likes (Given)
    33
    Likes (Received)
    4
    I call BS (Given)
    5
    9
    My car went 11.3 with 2.4 upper/injectors/intake/exhaust and street tires. Put welds and et streets on and it ran 10.9 with the same mods and tune.
    ERL416
    TVS2300
    RPS BC3 clutch
    Fore fuel system
    965wtq
    Quickest Manual V2 - 9.73 @146mph 1.44 60'
  14. #13
    Active Member
    Join Date
    Sep 2015
    Location
    NC
    Posts
    54
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Quote Originally Posted by NovaJeremy View Post
    Awesome. Do you remember what your 60' was with street tires?
  15. #14
    Active Member
    Join Date
    Jul 2014
    Location
    Ashburn, VA
    Posts
    139
    Likes (Given)
    33
    Likes (Received)
    4
    I call BS (Given)
    5
    9
    I actually don't remember exactly. I want to say mid 1.7
    ERL416
    TVS2300
    RPS BC3 clutch
    Fore fuel system
    965wtq
  16. #15
    Active Member
    Join Date
    Dec 2016
    Location
    Rancho Murieta, CA
    Posts
    341
    Likes (Given)
    0
    Likes (Received)
    4
    I call BS (Given)
    0
    0
    That's pretty damn impressive. Can you share any details on technique? Launch RPM? Slipping the clutch at all?
    - Airaid intake
    Hidden Content
  17. #16
    Active Member
    Join Date
    Aug 2013
    Location
    Central NJ
    Posts
    987
    Likes (Given)
    24
    Likes (Received)
    10
    I call BS (Given)
    1
    1
    I ran 11.7 @127 with 2.4 upper/headers/ported snout and TB/intake/tune on street tires
    after a cam and some more pulley with a drag radial went to 10.80@130
    2010 Manual V sedan:
    Track attack/LPE Varimax/Weapon X competition rad/2.5 upper/9.1 lower/100mm idler/50mm idler/Solid isolator/160tstat/ZL1 lid/-12 HX sytem lines/BMR ice box/ported blower/ported LS7 TB/Airaid/Longtube ARH/DMH cutouts/ID850s/stage 3 LT1Z cam/Moroso catch can/Core Shifter short shifter
    Tune by Tune Time
    Best:10.80 @132.31
    Hidden Content
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
