370z Track car for AER 2017
Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By m13s
  • 1 Post By m13s
Thread: 370z Track car for AER 2017
  1. #1
    Active Member
    Join Date
    Jan 2016
    Location
    Boston, North Shore
    Posts
    452
    Likes (Given)
    0
    Likes (Received)
    5
    I call BS (Given)
    0
    I call BS (Received)
    0
    Hi
    Going to New Orleans to pick up this car. It is a 2009 370z that will be driven by my team in the 2017 American Endurance Racing series. Team name: Bertil Roos Racing School Endurance Team.
    All drivers have extensive Formula car and sports car experience so we are looking forward to running the series in the new year.
    We will be keeping the motor fairly stock (reliability) and the suspension is lights out.
    Here are the car specs:
    Weight 2900 pounds
    HP 350 on 93 octane
    As it sits right now the car is 114 db, ungodly loud !
    Chassis
    TC Designs custom cage with reinforcement to firewall
    JRZ RS-Pro 2-way adjustable dampers with Hyperco springs
    SPL rear camber arms
    SPL rear toe links
    SPL rear knuckle monoball bushings
    SPC front camber arms
    Hotchkis sway bars
    Body
    Lexan front and rear
    Seibon carbon fiber hatch
    Aeromotions wing
    Stillen brake cooling
    Hood pins
    Drivetrain
    OS Giken 1.5 way differential with 3.54 gears
    Short shift
    Custom tilton/ setrab diff cooler with toggle switch
    Differential temperature gauge/ transmission temperature gauge
    * Diff Pump and cooler
    1 set of wheels: Enkei NT-03+M 18x10.5 mounted with new Hoosier r7,
    ARP long studs in 12x1.5
    Brakes
    Stoptech Trophy motorsports brakes with slotted rotors. 6 piston front, dual piston rear.
    Tevis stand alone motorsports ABS system with Tilton adjustable bias valve - Tevis is currently disabled
    Engine
    Stillen gen 3 intake
    Tuned for 93 octane 318 WHP/ 262 WTQ on Pellegrini Performance dynojet
    AE Performance oil cooler
    Oil pressure gauge
    AC delete
    Fuel starvation fix, Holley Hydra Mat on passenger side with second fuel pump
    Several custom SS exhaust set ups from Turbohose: single exit unmuffled, single exit with race muffler, single exit no muffler SuperTrapp, single exit with race muffler with SuperTrapp (Laguna set up).
    Long tube headers from Fast Intentions
    Interior
    Recaro Profi seat
    Sparco 330mm flat bottom steering wheel with quick release
    AFFF Fire system
    Schroth belts-
    Schroth right side net
    window net
    Custom carbon switch panel
    Custom dead pedal
    Battery relocated to trunk area
    We will be running 4 of the 7 races for 2017:
    21-23 April, Watkins Glen
    19-21 May NJMP
    15-17 September Summit Point
    20-22 October Mid ohio
    Any forum members are welcome to work the pits and help with the car, as extra hands are always welcome. Over the wall in the hot pits will require a fire suit and helmet.
    Mods, is there a CTSowners.com sticker ? If there is I will run it on the car and get some pictures, unless anyone has an objection.
    Wish us luck for 2017 !
    -M
    Attached Thumbnails Attached Thumbnails 370z Track car for AER 2017-img_5026.jpg 370z Track car for AER 2017-img_5027.jpg 370z Track car for AER 2017-img_5028.jpg 370z Track car for AER 2017-img_5029.jpg 370z Track car for AER 2017-img_5031.jpg
    370z Track car for AER 2017-img_5032.jpg 370z Track car for AER 2017-img_5033_0.jpg
    Mikeyboyeee likes this.
  2. #2
    Active Member
    Join Date
    Nov 2016
    Location
    St Louis Metro Area
    Posts
    224
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    That sounds like a hell of a lot of fun.
  3. #3
    Active Member
    Join Date
    Aug 2014
    Location
    Redmond, WA
    Posts
    2,507
    Likes (Given)
    0
    Likes (Received)
    198
    I call BS (Given)
    0
    5
    Wow, that looks awesome. Look forward to hearing how you guys do. Did you guys buy the car, or are you renting it?
    Hellastock CTS-Vegan
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Active Member
    Join Date
    Jan 2016
    Location
    Boston, North Shore
    Posts
    452
    Likes (Given)
    0
    Likes (Received)
    5
    I call BS (Given)
    0
    0
    team is made up of four guys, we formed an LLC and everyone has a 25% share that can be sold/bought. My Nissan was not up to the task so I broomed it and used the proceeds from it to start this team.
    Car, if reliable can podium in class 4. There are 5 classes, 1-5, slowest to fastest.
    Really looking forward to it.
    Wrecked Em likes this.
  6. #5
    jrV
    jrV is offline
    Active Member
    Join Date
    Feb 2015
    Location
    Wichita, KS
    Posts
    945
    Likes (Given)
    20
    Likes (Received)
    25
    I call BS (Given)
    0
    0
    That's pretty sharp! I love the body lines of the 370z. One of my favorite body's. Looks like a lot of fun to race. Good luck!
    As for stickers, you can help support the site and get some here:
    CTSVOWNERS Site Support Shirts/Hoodies/Stickers are here!!
    - 2011 TGC Sedan | A6 | Recaro's | Ultraview | Suede
    - 2015 Suzuki GSXR 1000
    - Stage β: AIRAID CAI w/green filter | Mamo Ported TB | DSX Flex Fuel Kit/Filter/Aux Fuel Pump Kit | ZL1 Lid | Fluidyne T-Rex HX | Varimax HX pump | Kook's Headers w/green cats | B&B axleback | 2.4" upper | ID1300's | LTZ1 stg 2.5 cam | Pat G Tuned
    - WTB: Ported TFS Heads | Ported blower/snout/102mmTB | Weld RT-S S71's and DR's
  7. #6
    Active Member
    Join Date
    Jan 2016
    Location
    Boston, North Shore
    Posts
    452
    Likes (Given)
    0
    Likes (Received)
    5
    I call BS (Given)
    0
    0
    Cool 'll order some stickers and get them on the car. Think about that, a Nissan with a CTSVowners.com sticker on it !
  8. #7
    Active Member
    Join Date
    Feb 2015
    Location
    Tampa, Fl
    Posts
    133
    Likes (Given)
    1
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Sweet looking car and very thoughtful mods. Good luck in the new season.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
