Stage 1.5ish build
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Need4V
Thread: Stage 1.5ish build
  1. #1
    Active Member
    Join Date
    Jan 2017
    Location
    Bay Area, Ca
    Posts
    120
    Likes (Given)
    3
    Likes (Received)
    2
    I call BS (Given)
    0
    I call BS (Received)
    0
    Stage 1.5ish build
    Well with much help from Matt(LT1z), Tyler @Mont, Artem Boyko and research from previous builds, the mod list is complete and parts are starting to roll in. Gonna be doing the work myself with the occasional help from my pops. He's 70 now but still enjoys being around projects and wrenching. Kind of a mix between typical stage 1 and 2 builds. Anyways here's my list
    Lt1Z Stage 2.5 with deluxe cam kit
    Johnson 2100 lifters
    GM lifted trays
    ARP head bolts
    Griptech 2.45 upper
    SW 2inch catless headers to 3 inch to stock mufflers(Thanks Tyler)
    Milled reinforced -12an Zl1 lid(Thanks Artem)
    Katech HX
    Airraid with green filter
    FIC 1000s
    Varimax
    Still deciding on either a ported or non ported 90mm TB. Would love to do a lower as well, but this is in my budget now. E85 would be sweet too, but we'll be buying a house next year that for sure won't have any stations within 30 miles. I'll be updating this thread with pics and progress whatnot as I work on it.
    Mont Motorsports likes this.
    Hidden Content
    2014 Phantom Gray M6
    Airraid Katech HX Zl1 lid milled reinforced -12an
    More to come....
  2. #2
    Active Member
    Join Date
    Apr 2013
    Location
    Calgary AB
    Posts
    4,520
    Likes (Given)
    0
    Likes (Received)
    114
    I call BS (Given)
    0
    9
    Do the lower if you are doing a cam install.
    I'd argue starting with the lower over the upper if a bump stick is going in the car.
    Also ported tb 87 or 90. I feel my tip in throttle better with a mamo 90 over mamo 87 but I doubt I gained much hp in the end.
    I'd argue against the arp head bolts unless you have big plans down the road, but if budget is tight I'd try to get that lower done and that may be what I would "cheap out on" to make the lower happen
    Current mods
    Lt1z stage 2 cam - johnson lifters - Dynospeed 4.5 intake/Green filter - Mamo LS7 ported TB - ARH headers and x-pipe to stock mufflers - Weapon X Track attack HX - weaponX carbon fiber spoiler and side blades - Varimax HX pump - NGK afx wide band - 2.45 Griptech upper - ATI lower 8.8 ring - Green belt - idler pulley - Id850s, Zl1 lid - NGK TR7ix - MSD wires - Mighty mouse catch can - BMR ice box - Side Swipe -
    160ish or 170 thermostat- Tuned.
  3. #3
    Active Member
    Join Date
    Jan 2017
    Location
    Bay Area, Ca
    Posts
    120
    Likes (Given)
    3
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    Unfortunately it's just not in the budget for a lower. Don't want to use my credit card for any of these mods. The head bolts don't equal the price of an ATI with 8.6 pulley, so it is what it is. In 6-12 months when I get the next round going, I'll do it then. I'm doing the labor so it's just time. I agree with the ported TB. Just gotta hope I find one for a decent deal.
    Hidden Content
    More to come....
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Registered User
    Join Date
    Mar 2016
    Location
    Texas
    Posts
    34
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    OE Head bolts are TTY, so if you're pulling the heads, might as well go ARP rather than new TTY bolts. It may be over kill, but they are reusable down the line which is nice. Id def do a lower if you're doing a cam though.
    ATK High Performance Engines
    Street-Strip-Racing Engines
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
