Fuel pump hatch
Results 1 to 7 of 7
Thread: Fuel pump hatch
  1. #1
    Active Member
    Join Date
    Feb 2014
    Location
    Somewhere out there
    Posts
    362
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    I call BS (Received)
    1
    Fuel pump hatch
    For you guys who had to cut the hole for the pump drop-in, if you didn't use the hatch that jlinks sell, what did you use instead?
  2. #2
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    12,870
    Likes (Given)
    0
    Likes (Received)
    375
    I call BS (Given)
    0
    12
    I am not aware of anyone else making a hatch for the V. Why bother when jlinks is tried and true and cheap
    679RWHP 662RWTQ
    BMF cam
    Ported SC/Snout/90TB
    Kooks LT w/cats stock muffs
    ID850's
    IW 9.1/2.55
    Airaid w/green filter
    Katech+W4M HX ZR1 pump
    Norcal ice tank
  3. #3
    Active Member
    Join Date
    Feb 2014
    Location
    Somewhere out there
    Posts
    362
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    1
    I'm going to order one from him, I just need to get it sealed up until the one from him comes in, he doesn't have the means to get one out to me this week and I needed it sealed for or by the weekend so I'm looking for an alternative until I can get my hands on his....now...do you have any other idea of how I could seal it in the mean time?
  4. #4
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    12,870
    Likes (Given)
    0
    Likes (Received)
    375
    I call BS (Given)
    0
    12
    Fuel pump hatch
    Duct tape the piece you cut out?
    679RWHP 662RWTQ
    BMF cam
    ID850's
    IW 9.1/2.55
    Norcal ice tank
  5. #5
    Active Member
    Join Date
    Nov 2013
    Location
    Hurst TX
    Posts
    769
    Likes (Given)
    0
    Likes (Received)
    7
    I call BS (Given)
    0
    0
    I used some rubber sealant tape that we use at work and the piece I cut out. Basically covered all the edges on the body and the piece I removed with the tape and then stuck it back in. And then covered it all with foil tape. Worked perfect and I know no fums or exhaust will get in, that stuff seals tight as hell it is used to seal cable entrys on fiber splice cases.
    I ordered the hatch, but I think mine was not bent correctly to fit the opening. I still have to get in touch with him about a possible refund as my current solution works and can still be opened if needed.
    ID850's, 2.4 upper, Track Attack HX, Varimax pump, ZL1 Lid, Texas Speed headers, Airaid with green filter, PLX wideband.
  6. #6
    Active Member
    Join Date
    Mar 2014
    Location
    South Jersey
    Posts
    695
    Likes (Given)
    0
    Likes (Received)
    12
    I call BS (Given)
    0
    4
    Quote Originally Posted by thereason View Post
    I drove around for a week or two without the hatch cover on. I just put the seat cushion in and it was fine.
  7. #7
    Active Member
    Join Date
    Feb 2014
    Location
    Somewhere out there
    Posts
    362
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    1
    Quote Originally Posted by Eleventeen View Post
    Cool, thanks all. Going to place my order with him today, just didnt know if it was safe to ride around without it or if one could be temporarily made.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
