850's = tune or no tune
Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By Eleventeen
Thread: 850's = tune or no tune
  1. #1
    "V"roooooom
    Join Date
    May 2015
    Location
    Pooler, GA
    Posts
    21
    Likes (Given)
    2
    Likes (Received)
    0
    I call BS (Given)
    0
    I call BS (Received)
    0
    Do I have to have a tune done after upgrading to 850 injectors? This is my dd.
    Hidden Content
    2011 CTS V, RECAROS, ULTRAVIEW, EIBACH SPRINGS, CROSS DRILLED AND SLOTTED ROTORS, CF AIRAID, PORTED LS7 TB, PORTED SNOUT, MUFFLER DELETE, (2.5 PULLEY AND 850 INJECTORS - NOT INSTALLED)
  2. #2
    Active Member
    Join Date
    Apr 2013
    Location
    Calgary AB
    Posts
    4,078
    Likes (Given)
    0
    Likes (Received)
    106
    I call BS (Given)
    0
    8
    yes.
    Are you doing other mods? Even if you just put in id850 they flow differently so the ECU needs that data. You need a tune no way around it unless you want to kill your motor right away.
    Current mods
    Lt1z stage 2 cam - johnson lifters -Airaid CAI w/Green filter - Mamo ported TB - Corsa Sport cat backs - Weapon X Track attack HX - weaponX carbon fiber spoiler and side blades - Varimax HX pump - NGK afx wide band - 2.4 upper - Green belt - idler pulley - Id850s, Zl1 lid - NGK TR7ix - MSD wires - BB test pipes - Mighty mouse catch can - BMR ice box - Side Swipe. Tuned.
    Mod pile
    American Racing headers and Xpipe - ATI lower 8.8 ring
    Best 1/4 mile to date
    1800DA
    1.67 - 60foot
    125.24 mph - 1/4
    11.1489 - Still working on the tune
  3. #3
    Active Member
    Join Date
    Aug 2016
    Posts
    138
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    Quote Originally Posted by P's2011V View Post
    My personal understanding when switching injectors to something other than stock, is you will need to have your tuner flash the compu BEFORE you even try and start or you will flood it, then get a tune/re-tune. I just went to the 850's and my tuner who's a good dude came to the house with a base program to flash my car so I can drive it to his shop (instead of rollback) for tuning/dyno work.
  4. #4
    Active Member
    Join Date
    Apr 2013
    Location
    Calgary AB
    Posts
    4,078
    Likes (Given)
    0
    Likes (Received)
    106
    I call BS (Given)
    0
    8
    Quote Originally Posted by Florida-Vee View Post
    Even worse I think the cylinder walls will wash out and you will damage the motor. Ive heard of some guys driving too the tuner then the motor dies while on the dyno. Could be bad luck or could have put so much fuel into the cylinders that the oil was watered down and kaboom
    Current mods
    Mod pile
    1800DA
    1.67 - 60foot
    125.24 mph - 1/4
  5. #5
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    12,848
    Likes (Given)
    0
    Likes (Received)
    375
    I call BS (Given)
    0
    12
    Stock tune will run 850's to get them to your tuner. But they must be tuned.
    679RWHP 662RWTQ
    BMF cam
    Ported SC/Snout/90TB
    Kooks LT w/cats stock muffs
    ID850's
    IW 9.1/2.55
    Airaid w/green filter
    Katech+W4M HX ZR1 pump
    Norcal ice tank
  6. #6
    Active Member
    Join Date
    Aug 2016
    Posts
    138
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    Quote Originally Posted by t.j.t View Post
    I saw it done (washing the cylinders) in the early 90's when guys were adding crap to their fuel on the vettes and the injectors were not built to use additives that guys were trying. Luckily my tuner has tuned cars with 850's so he just dropped it on mine and said "no boosting just bring it to the shop" lol..
  7. #7
    Join Date
    Jul 2011
    Posts
    9,636
    Likes (Given)
    214
    Likes (Received)
    170
    I call BS (Given)
    0
    3
    Stock tune will piss almost twice as much fuel as requested down the cylinders on the stock tune until the trims max out and pull 25% or so back out. Highly recommended that you either wait to install them at the tuner or get sent a base tune to load and then drive to the tuner. Driving untuned injectors that are 10 lb/hr bigger are not a huge deal. Going from 52 to almost 100 lb injectors is IMO.
  8. #8
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    12,848
    Likes (Given)
    0
    Likes (Received)
    375
    I call BS (Given)
    0
    12
    I prefer to drop a base tune in, but 20 miles won't kill it.
    Not suggesting to drive it that way and getting tuned in a few days.
    Straight to tuner.
    679RWHP 662RWTQ
    BMF cam
    ID850's
    IW 9.1/2.55
    Norcal ice tank
  9. #9
    Active Member
    Join Date
    Mar 2014
    Location
    South Jersey
    Posts
    693
    Likes (Given)
    0
    Likes (Received)
    12
    I call BS (Given)
    0
    4
    Absolutely. My tuner was about an hour and fifteen minutes away, so I went through the motions of swapping out the injectors at my house, without actually installing he new injectors. This allowed me to figure out exactly what tools I needed to take with me to the tuner. I showed up an hour early and did the swap in the tuner's parking lot.
    P's2011V likes this.
  10. #10
    Join Date
    Jul 2011
    Posts
    9,636
    Likes (Given)
    214
    Likes (Received)
    170
    I call BS (Given)
    0
    3
    Straight to tuner.
    Not something I would suggest to someone as OK. I know some get away with it but people do all kinds of things they probably should avoid.
  11. #11
    Jim
    Jim is offline
    Registered User
    Join Date
    Dec 2016
    Posts
    15
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    I don't mean to thread jack so forgive me for jumping in here but I've got a set of ID850's on the way that I was planning on installing next week or the following week. If I flash the proper injector data through HP Tuners will the tune need to be modified or will the injector data be sufficient? The only mod on the car right now is an Airaid intake and a few tuning changes to the transmission. I plan on doing more mods in the very near future but wanted to get the injectors done first. Next mods will be ported TB and snout, pulley(s) and cat delete followed up by some cooling mods.
    Thanks!
  12. #12
    Active Member
    Join Date
    Jun 2013
    Location
    Da Rock
    Posts
    3,527
    Likes (Given)
    81
    Likes (Received)
    127
    I call BS (Given)
    5
    4
    why bother doing the injectors when they aren't supporting anything? You have nothing to gain by installing them now and they're so easy to do, wait until you do the other mods.
    '12 WD non-wagon
  13. #13
    Join Date
    Nov 2013
    Location
    Phoenix
    Posts
    1,852
    Likes (Given)
    36
    Likes (Received)
    22
    I call BS (Given)
    0
    0
    Just like everyone else said, any time injectors are changed to a different rate then you 100% require a tune.
    Hidden Content
    Brands you can find at the Black Market!
    Procharger | Whipple | Borg Warner Turbos | Injector Dynamics | JMS| ARH | Cobb | Fore | Squash | Meisterschaft | Weld Wheels | Forgestar | MRR Wheels | M&H Tires | MHT Wheels | Weds Wheels | ProEFI | Megasquirt
    and many more! Call 480-382-1696 or email Hidden Content
    Hidden Content
  14. #14
    Jim
    Jim is offline
    Registered User
    Join Date
    Dec 2016
    Posts
    15
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Got it. At first I was planning on buying pulleys first but didn't want to risk installing them and running lean so I picked up the injectors at a great price and figured installing them wouldn't hurt anything as long as I adjusted the tune to run the injectors. My V is a DD so I try to schedule things that I can get done in a day and will get a few other pieces purchased before installing the injectors.
    Thanks!
  15. #15
    Join Date
    Jul 2011
    Location
    Los Angeles
    Posts
    14,662
    Likes (Given)
    341
    Likes (Received)
    307
    I call BS (Given)
    10
    19
    Injectors swapping shouldn't take long, you can probably do it in the parking lot before your drop it off.
    Sales@dynamicflowconcepts.net
    Dynamicflowconcepts.net
  16. #16
    Jim
    Jim is offline
    Registered User
    Join Date
    Dec 2016
    Posts
    15
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Closest drop off place from me is 200+ miles so I get to do all of my own work and while I've been tuning my own vehicles with HP Tuners for a few years now, I'll go with a reputable tuner and have a remote tune done as I'm still getting my feet wet on this platform.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
