V2 WEAPON-X Griptec Upper Pulleys - 2.5, 2.4, 2.3, and 2.17!
Results 1 to 15 of 15
Like Tree3Likes
  • 1 Post By gOt BoOsT
  • 1 Post By Typhoon43
  • 1 Post By phatj33pyj
Thread: V2 WEAPON-X Griptec Upper Pulleys - 2.5, 2.4, 2.3, and 2.17!
  1. #1
    I'm Your Pusher
    Join Date
    Jul 2011
    Location
    Cin City
    Posts
    11,016
    Likes (Given)
    396
    Likes (Received)
    145
    I call BS (Given)
    1
    I call BS (Received)
    2
    CTS-V2 Racing by WEAPON-X Motorsports ? Griptec Pulley Combos for LSA, LT4, LS9, etc. CTS-V, C7 Z06, C6 ZR1
    We've worked closely with Griptec to come up with some proprietary co-branded pulleys for the LT4 CTS V gen 3!
    Upper kits are only $199 and you can do up to a 15% upper and we offer full snout porting and pulley press/pinned on these for $550 more. 103mm snout option available as well!
    And yes we have cores to swap
    Who's ready to go faster?!
    The WEAPON-X Griptec pulleys are the new latest and greatest in pulley technology for your CTS V2. The WEAPON-X versions are spec'ed out based on the 1.9L supercharger's capabilities in our proprietary sizes Pick your poison, but if you need help, call our supercharger specialists and we can make sure you're running the best combo for your setup!
    GripTec® Micro is a micro ablation machining process. Our micro machining capabilities are near limitless and we apply our technology to give the target component an engineered surface design that optimizes the safest most aggressive gripping force possible. Our multi directional machined ridges and valleys offer up more than just maximum gripping force they also act as escape ducts for trapped air and debris further helping in the mating of the target surface and belt. US Patent 9,421,637
    Belt slip is a very common issue on supercharged components. In fact some units cranking out as much as 14-16 psi can take up to 200hp to drive. Often the drive systems are plagued with slippage issues and builders find themselves moving to noisy cog systems, where belts have shorter life spans, are difficult to find at just any parts store and they can create more heat through the frictional movement of the cogs.
    Belt slip isn't always noticeable. Often belt slip is noticed when the system squeals, squeaks or boost falls off. Did you know that naturally the belt can slip a very small percentage even on NA vehicles, one major factor to belts wearing. Belt wrap does play a key factor in minimizing belt movement but when it comes to driving a supercharger is hard to fully eliminate with just surface contact. Systems running 3.4 upper pulleys can see as much as a 1.5 psi gain when matching size for size pulleys.
    Whether you are running 6 psi or 20+ psi you are slipping if you are not running GripTec®
    Pro's to using GripTec®
    Increased boost and supercharger performance size for size pulley
    Reduce or eliminate belt slippage on the applied component
    Increase belt life from not slipping over and over again
    Eliminate belt squeaks common when shifting hard
    Con's
    To much boost for current engine tune. Adjustment may be required.
  2. #2
    Autism Speaks. Listen
    Join Date
    Oct 2012
    Location
    Sacramento, Ca
    Posts
    1,149
    Likes (Given)
    26
    Likes (Received)
    30
    I call BS (Given)
    2
    0
    Good shit Ben...those came out nice!
    Sent from my iPhone using TapaMilf
    Red Baron likes this.
    2014 Esky Blk/Blk Loaded
    Stock
    2011 CtsV Blk/Blk Loaded
    Under Construction...
    2011 S4 Quartz/Blk Loaded
    034 Stg3 11.55@119mph 91/E85 +1360Da
    2011 RxpX Turbo Blk/Fire
    E85 Monster Hidden Content
  3. #3
    Active Member
    Join Date
    Aug 2014
    Location
    In a Garage or a Bar..or a garage with a bar in it.
    Posts
    1,352
    Likes (Given)
    2
    Likes (Received)
    63
    I call BS (Given)
    0
    0
    Those pulleys are so damn sexy. Love it.
  4. #4
    Active Member
    Join Date
    Jul 2015
    Posts
    98
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Will these fit the lpe hub? I have it already and want move to a smaller pulley.
  5. #5
    Join Date
    Jul 2011
    Posts
    9,656
    Likes (Given)
    214
    Likes (Received)
    170
    I call BS (Given)
    0
    3
    Are these for the ZPE hub or LPE?
  6. #6
    I'm Your Pusher
    Join Date
    Jul 2011
    Location
    Cin City
    Posts
    11,016
    Likes (Given)
    396
    Likes (Received)
    145
    I call BS (Given)
    1
    2
    Quote Originally Posted by suttererman85 View Post
    Quote Originally Posted by Lt1z View Post
    Both Matt
  7. #7
    Registered User
    Join Date
    Oct 2016
    Posts
    24
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    thanks guys, ordered one up !
  8. #8
    Registered User
    Join Date
    Jun 2016
    Posts
    13
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    Will the 2.31 pulley for the LT4 V3 fit the LPE hub? i gave a 2.38 on it now. Also will it still retain the factory belt like the 2.38 does or will i need a new one?
  9. #9
    I'm Your Pusher
    Join Date
    Jul 2011
    Location
    Cin City
    Posts
    11,016
    Likes (Given)
    396
    Likes (Received)
    145
    I call BS (Given)
    1
    2
    Quote Originally Posted by bpscz06 View Post
    yes I make pulley rings for the LPE hub, 2.31 is an oddball number though. I can do a 2.25 or 2.3 on there.
  10. #10
    Active Member
    Join Date
    Jul 2016
    Location
    Fort Worth, TX
    Posts
    187
    Likes (Given)
    1
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    To run the 2.17 will i need to machine the snout? Also is that a to small of a pulley for a catless and e85 car? Cant decide on the 2.17 or 2.30
  11. #11
    Active Member
    Join Date
    Mar 2015
    Posts
    2,069
    Likes (Given)
    0
    Likes (Received)
    39
    I call BS (Given)
    0
    3
    Which of these uppers will need to have a machined snout to fit?
    09' Thunder Gray Chroma Sedan | 6AT | UltraView | Eibach Springs | Velgen VMB5's
    "Factory Freak"
    Mod Pile reaching Critical Mass
  12. #12
    I'm Your Pusher
    Join Date
    Jul 2011
    Location
    Cin City
    Posts
    11,016
    Likes (Given)
    396
    Likes (Received)
    145
    I call BS (Given)
    1
    2
    Quote Originally Posted by zdeckich View Post
    Quote Originally Posted by VVVROOMTX View Post
    Yes, you'll need to machine the snout on these. We offer full services with the snout machined, pulley pressed and pinned, porting etc!
  13. #13
    Active Member
    Join Date
    Mar 2015
    Posts
    2,069
    Likes (Given)
    0
    Likes (Received)
    39
    I call BS (Given)
    0
    3
    Quote Originally Posted by Red Baron View Post
    The 2.45 and 2.5 shouldn't need machining and the 2.17 i know will for sure but the 2.3 will need machining as well?
    "Factory Freak"
  14. #14
    Active Member
    Join Date
    Jul 2016
    Location
    Bowling Green, Ky.
    Posts
    55
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Dang I just missed this.
    '09 Radiant Silver Sedan A6
    _________________________________
    Weapon-X Stage 3 CNC LSA heads | Weapon-X Stage 2 Cam | 102mm ported Snout and Inlet | LPE balancer w/ LPE 9.1 lower | 2.55 Upper | E85 Flex Fuel Conversion | NGK TR7IX | ID850cc Injectors | Nick Williams 102mm DBW Throttle Body | Weapon-X 4.5" Intake | ZL1 lid with -12an lines | Weapon-X Track Attack HX | Varimax pump | ARH headers w/ 3” Catted X-Pipe to Stock Mufflers with DMH Duel Electric Cutouts
    656whp / 579wtq (Mustang Dyno)
    Exterior
    Weapon-X carbon fiber outer hood with vents
    Black Moon Products ‘Rocker Blades’
    Black Moon Products Splitter
    Black Moon Products CF Wrapped Grille
    '15 Escalade Rear Emblem
    '15 ATS-V Front Emblem
    '15 ATS-V Black Center Caps w/Chrome Crest
  15. #15
    Active Member
    Join Date
    Feb 2014
    Location
    Detroit
    Posts
    765
    Likes (Given)
    2
    Likes (Received)
    39
    I call BS (Given)
    0
    0
    Is this still available?
    2010 V 6MT - Thunder Gray, Recaros, Headers, Corsa Exhaust, Hennessey CAI, Velgen 20" wheels, Pilot SS tires
    2006 V -Sold
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
Search tags for this page
griptec pulley
Tags for this Thread
