Which 19" tire gives best hook for cheapest price?
Results 1 to 24 of 24
Like Tree2Likes
  • 1 Post By larry arizona
  • 1 Post By Wrecked Em
Thread: Which 19" tire gives best hook for cheapest price?
  1. #1
    Registered User
    Join Date
    Apr 2016
    Posts
    4
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    I call BS (Received)
    0
    I need to replace my 19" stock rear tires because someone (I guess myself) spins the things so often that they're bald!
    Need better hook up. Want to stay with run-flats because I'm not carrying a spare.
    I saw the Firestone firehawk wide oval FRT for $312 on tirerack but it says "for corvette use only".
    the next cheapest is the Pilot Sport A/S Plus ZP for $357 but that's an all season tire.
    I don't mind a summer tire if it gives better hook-up. thoughts?
    thanks
  2. #2
    Active Member
    Join Date
    Jun 2012
    Location
    Spring/Woodlands TX
    Posts
    14,239
    Likes (Given)
    62
    Likes (Received)
    580
    I call BS (Given)
    0
    11
    Drag radials? Slicks? Steet legal? What size wheel are you running? A little more info will be helpful.
    2014 OBM/Titanium CTS-V Wagon "The Blue Whale"
    Auto, All Options, Interior 100% stock.
    Custom touches here and there...needs driver mod badly!
    7xx to 8xx rwhp
    2015 Audi SQ5 Prestige Glacier White Metallic + Gloss Piano Black trim "Snow White"
    Black leather interior, 8 Spd ZF Auto, all options
    Pulley and tune
    21" RS6 wheels /Super Sport 285's all around / Lowered on KW's
  3. #3
    Active Member
    Join Date
    Jun 2012
    Location
    Spring/Woodlands TX
    Posts
    14,239
    Likes (Given)
    62
    Likes (Received)
    580
    I call BS (Given)
    0
    11
    Oops...sorry, missed the run flat requirement. That said ANY run flat is going to be poor for traction. The reason being that run flats have very stiff sidewalls to support the car with no air pressure. So with a lot less sidewall flex you are going to have problems with traction on ANY brand, make, or model...
    7xx to 8xx rwhp
    Pulley and tune
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Registered User
    Join Date
    Apr 2016
    Posts
    4
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Quote Originally Posted by TriTexan View Post
    Just street tires. Same size as originals.
    I then plan on painting my stock wheels black and putting on a red pinstripe
  6. #5
    Registered User
    Join Date
    Apr 2016
    Posts
    4
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    But if I don't get run flats, what do you guys do if you get a flat? call a truck?
    then what is the best tire in stock size 19" if not run flat?
  7. #6
    Active Member
    Join Date
    Nov 2012
    Location
    Posts
    13,255
    Likes (Given)
    0
    Likes (Received)
    385
    I call BS (Given)
    0
    13
    Quote Originally Posted by 90ZR1 View Post
    Inflator kit in the trunk or find a spare tire kit, there are several out there
    neuronbob likes this.
    679RWHP 662RWTQ
    BMF cam
    Ported SC/Snout/90TB
    Kooks LT w/cats stock muffs
    ID850's
    IW 9.1/2.55
    Airaid w/green filter
    Katech+W4M HX ZR1 pump
    Norcal ice tank
  8. #7
    Join Date
    Jul 2011
    Location
    Los Angeles
    Posts
    15,445
    Likes (Given)
    364
    Likes (Received)
    327
    I call BS (Given)
    10
    19
    Run flats suck...sorry.
    For CNC ported blowers and more, visit:
    Dynamicflowconcepts.net
  9. #8
    Active Member
    Join Date
    Jun 2012
    Location
    Spring/Woodlands TX
    Posts
    14,239
    Likes (Given)
    62
    Likes (Received)
    580
    I call BS (Given)
    0
    11
    This.
    Quote Originally Posted by Karch View Post
    ...and This.
    7xx to 8xx rwhp
    Pulley and tune
  10. #9
    Active Member
    Join Date
    Aug 2014
    Location
    Redmond, WA
    Posts
    2,436
    Likes (Given)
    0
    Likes (Received)
    191
    I call BS (Given)
    0
    4
    AAA
    AARPCTSV likes this.
    Hellastock CTS-Vegan
  11. #10
    Active Member
    Join Date
    Oct 2013
    Location
    Burleson, Tejas
    Posts
    2,138
    Likes (Given)
    0
    Likes (Received)
    83
    I call BS (Given)
    0
    7
    All seasons suck for for hooking up too.
    What power level are you? If stock, check out conti DW. If not, be ready to pay more for traction.
    You know going lighter on your right foot and leaving the traction control on can control that spinning and in return help your tires not wear as quickly.
    3/4 race cam in a 'Vette engine, roller muffler bearings, extra back pressure for more torque, traction bars, cross drilled brake lines, low profile tires, and dual whistle tips.... WOOO WOOOO!
  12. #11
    Active Member
    Join Date
    Jan 2016
    Location
    Las Cruces NM
    Posts
    1,177
    Likes (Given)
    0
    Likes (Received)
    58
    I call BS (Given)
    0
    1
    Nitto 555G2. Just got a new set. I'm at noob power but they hook every bit as well as the mpss I took off. Stock sizes and way cheaper too
  13. #12
    Active Member
    Join Date
    Jul 2012
    Posts
    585
    Likes (Given)
    0
    Likes (Received)
    13
    I call BS (Given)
    0
    0
    Quote Originally Posted by Mprtetr View Post
    Where did you get then from and how much?
  14. #13
    Active Member
    Join Date
    May 2015
    Posts
    509
    Likes (Given)
    0
    Likes (Received)
    4
    I call BS (Given)
    0
    0
    run flats and hooking? LOL. I don't think anybody understands the term of "hooking" No street tire is going to "hook"
    2012 CTS-V Coupe 29k Miles 730hp/697 SOLD!
    Black Diamond Tricoat, Titanium Recaroes, Leather Steering Wheel
    Color Matched Grille Shell, Color Matched Tinted Tails, Trunk Bar, and Fog Light Bezels
    VLEDS 5000k Interior LEDS & 5000k LED Fogs
    Magnaflow 5x11" Exhaust Tips
    255/315 Michelin PSS
    Gforce 4.5 Intake, NW102, FIC1000s, LT1Z Stage 2.5 Cam, Kooks LTs & Catless X, Ported Snout,
    Upper & Lower Pullies, DSteck Fuel System on E85, Plugs & Wires, G-Force Heat Exchanger, QTP Cutouts, Tuned by Mike @ G-Force Motorsports in Pearland Texas
    NEW 2017 Corvette Grand Sport 8xxwhp
    F1A Procharger
    Kooks 2" to Catless X Pipe Jet Coated and DEI Titanium wrapped
    Alky Duel Nozzle Meth
    GPtuning LT1Z Blower Cam
    ARP Studs, Vengeance Drop in Pistons
    Z06 19x12 Reps wrapped in 345 NT05Rs
    2012 Ram 2500 6.7L Cummins 4x4 20k Miles Px8 Black 450HP/930TQ
    10.5" BDS Lift Kit Powder Coated Gloss White
    22x14 American Force Independences Powdered Gloss White and Wrapped in 40x15.50 Toyo M/Ts
    Tune (H&S), Exhaust (Diamond Eye DPF delete), S&B CAI
    Custom Retro Fitted HeadlightsW 55W 5k Morimoto HIDS and Retrofitted Tail lights
    Royalty Core Custom Grille
    Rigid Industries Quad D2s (Front) Flush Mounts In bumper (Rear)
    Ipad Dash, Hydro Dipped Interior White W/Black Wood Grain W/Roadwire Custom Leather Seats
    A Million other modifications that won't fit a signature.
    Hidden Content
  15. #14
    Active Member
    Join Date
    Nov 2015
    Location
    South Florida
    Posts
    194
    Likes (Given)
    2
    Likes (Received)
    6
    I call BS (Given)
    3
    0
    I've had good luck with the RE-11's. They have a 180 tread wear, they are pretty soft. Read some reviews on them. Most everyone loves them.
    '13 BD Vagon, manual trans, recaros, alcantara, sunroof, yellow calipers.
    2.4 pulley, ID850's, headers and 3" full exhaust, Zl1 lid, ported LS7 TB, airraid w/ green filter, varimax, track attack hx, catch can and custom icebox.
  16. #15
    Active Member
    Join Date
    Oct 2013
    Location
    Burleson, Tejas
    Posts
    2,138
    Likes (Given)
    0
    Likes (Received)
    83
    I call BS (Given)
    0
    7
    Quote Originally Posted by Chaney View Post
    A DR has problems hooking on the street unless you prep.
    Some street tires are much less traction limited than others. The re11 for instance does surprisingly well, even exceeding the DW.
  17. #16
    Active Member
    Join Date
    Mar 2015
    Posts
    2,158
    Likes (Given)
    0
    Likes (Received)
    40
    I call BS (Given)
    0
    3
    My vote is for the 305/30-19 Bridgestone RE11, if you can find htem
    09' Thunder Gray Chroma Sedan | 6AT | UltraView | Eibach Springs | Velgen VMB5's
    "Factory Freak"
    Mod Pile reaching Critical Mass
  18. #17
    It's got an intake tube!
    Join Date
    Jan 2012
    Location
    State of Confusion
    Posts
    7,948
    Likes (Given)
    572
    Likes (Received)
    224
    I call BS (Given)
    28
    21
    RE11s here...
    2011 White Diamond Sedan A6, 10.7 @ 130 (stage 1)
    750 RWHP (138ish through the trapper) So far... (stage 2)
    Click here -> Hidden Content
    Hidden Content
  19. #18
    Active Member
    Join Date
    Mar 2013
    Posts
    3,359
    Likes (Given)
    617
    Likes (Received)
    113
    I call BS (Given)
    402
    115
    That would be a used set of pilot sports off ebay with 80% tread for the win!
    Currently slumming it in a Jeep SRT and watching Gen 3 V prices for my next car!
    2011 CTS-V Coupe -WeaponX carbon fiber trim. (sold)
    Originally Posted by WD2009CTSV
    1/2 tenth on the big end and a little more weight in the pocket. And that's like a sore dick, you just can't beat it!
  20. #19
    Active Member
    Join Date
    Jan 2016
    Location
    Las Cruces NM
    Posts
    1,177
    Likes (Given)
    0
    Likes (Received)
    58
    I call BS (Given)
    0
    1
    Quote Originally Posted by acblack View Post
    I got them from my local guy. Gave me a crazy deal.
    https://www.onlinetires.com/products...2+xl+103w.html
    I'd get ahold of Jon @ BWD and see what he's got.
  21. #20
    Registered User
    Join Date
    Jan 2015
    Posts
    41
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    0
    Toyo r888 are great but not the cheapest
  22. #21
    Registered User
    Join Date
    Aug 2013
    Posts
    45
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    +1 RE11's 285/35/19
  23. #22
    Active Member
    Join Date
    May 2014
    Location
    Lexington, KY
    Posts
    101
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    Cooper RS3-S are decent tires at a reasonable price. I popped one of my OEM rear tires on some road debris (sidewall) w/ only 7K miles. Then I popped one of the fronts in a fender bender w/ only 9K miles. I only replace tires in pairs so I'm running Michelin Pilot Super Sports in the front and the Coopers in the rear. All OEM size. Both sets have a UTQG of 300/AAA so I still have balanced grip. It was around $500 for each set. I recommend you avoid directional tires, so you can at least still rotate side to side. Stickies will cost more, especially the rears...Happy shopping...
    2014 V Wagon M6
    2016 SRX4 Performance Edition
  24. #23
    Active Member
    Join Date
    Jun 2012
    Location
    Spring/Woodlands TX
    Posts
    14,239
    Likes (Given)
    62
    Likes (Received)
    580
    I call BS (Given)
    0
    11
    Michelin Pilot Sport Cup 2.
    7xx to 8xx rwhp
    Pulley and tune
  25. #24
    Active Member
    Join Date
    Jan 2016
    Posts
    1,231
    Likes (Given)
    0
    Likes (Received)
    20
    I call BS (Given)
    0
    0
    I'm probably going conti Dw for my rears soon. 305 with stock size fronts in case anyone wants to talk me out of them stockish power now.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
Search tags for this page
tire
